Leaking Valve Cover Gasket 2002 2.7 - Hyundai Forums : Hyundai Forum
Old 01-18-2010, 05:35 PM   #1 (permalink)
SFSam
Smelling strong fumes when stopped in traffic or backing up. No exhaust leaks. Mechanic found oil leak from rear valve cover onto exhaust manifold. He tells me that replacement of this gasket is a 2 to 3 hour job @ $250 labor and $100 parts (approx) Is this reasonable?
SFSam is offline   Reply With Quote Quick reply to this message
Old 01-18-2010, 05:39 PM   #2 (permalink)
jsinton's Avatar
Is it the dealer or third party shop?
The gaskets can be had for under $50
Old 01-18-2010, 08:50 PM   #3 (permalink)
SFSam
QUOTE (jsinton @ Jan 18 2010, 05:39 PM)
Having a little trouble with the protocol. It's a third party shop. They were quoting approx gasket set prices from memory of a recent similar job.
Old 01-18-2010, 09:04 PM   #4 (permalink)
jsinton's Avatar
If it was my car, I'd try two things:
First of all, I go around all the valve cover bolts and try to tighten them down a little first. Then I change my oil with "high mileage" stuff because is has seal conditioners that cause seals and gaskets to swell up a little. If that didn't work, then I'd just buy the gaskets off eBay for $40 and change it myself.
Old 01-18-2010, 10:02 PM   #5 (permalink)
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
I cleaned up your posts for you...carry on.
- Andrew
Titanium Gray / Gray Leather
lovemysantafe is online now   Reply With Quote Quick reply to this message
