Removing Crankshaft Pulley Bolt - Hyundai Forums : Hyundai Forum
Old 06-23-2006, 02:27 PM   #1 (permalink)
hyundaistepdad
I tried in vain to remove the crankshaft pulley bolt and wondered if there are any tricks to removing it?
It isn't left hand thread, right?
hyundaistepdad is offline   Reply With Quote Quick reply to this message
Old 06-23-2006, 04:21 PM   #2 (permalink)
ADMINISTRATOR
Montego's Avatar
this bolt can be very tight, it's not a left hand thread. the best method is to use an air wrench (3/4 drive if you can) but if you do not have acsess to this try a socket on a long swing bar, fit it on the crankshaft pulley bolt at around four a clock position and flick the starter switch so that the swing bar hits the ground and with luck the inpact will losen the bolt (make sure the swing bar hits something solid when it hits the ground) or you could remove the starter motor and have a pal jam a large screwdriver in the flywheel ring gear while you loosen the bolt (don't try this on vehicles with auto trans. or you could damage the drive plate)
MONTEGO
Old 07-03-2006, 01:06 PM   #3 (permalink)
hyundaistepdad
I have successfully removed the crankshaft bolt by the following method:
1) I bought a piece of "c" channel from home depot and drilled three holes the same pattern as the ones that hold the pulley on. I cut a slot for the crank bolt. This is 36 inches long and heavy duty. I propped it against the front frame rail. Tightened the bolts very tight to avoid damage.
2) I then put a 22MM 6 sided socket (actually 7/8") on the bolt, a short extension, and a 3/4 inch breaker bar (round). I made an extender with a piece of 3/4 black iron pipe. I jacked the car up taller and put in on a heavy duty jack stand. The piece of pipe I could fit under the car was 21". I braced myself on the steering knuckle and pulled very hard and it finally came loose.
Air impact wrench, and starter method did not work. Good ideas, but alas a BFW was the solution.
If anyone is interested, I'll post pics of the bar.
Cheers.
Old 02-27-2011, 04:44 PM   #4 (permalink)
mariestanley40@yahoo.com
Send a message via Yahoo to mariestanley40@yahoo.com
HEY !!!!!!!!!!!!!!!!!!!!
HYUNDAISTEPDAD------------I NEED YOUR HELP. IM HAVING A HELLOVA TIME TRYING TO GET THIS CRANKSHAFT BOLT OFF SO I CAN GET TO THE CRANKSHAFT POSIONTIONING SENSOR AND THE BALANCE SHAFT BELT. THE COMPUTER CODE SAYS ITS THE SENSOR, BUT SINCE WE HAVE GOTTEN DOWN TO THAT BOLT, HAVE RELIZED THAT THE SMALL BELT IS BROKE, AS WELL. NOT SURE IF THE DIAGNOSTIC IS READING CORRECTLY BUT EITHER WAY I NEED TO REMOVE THAT BOLT. YOU MENTIONED A TOOL THAT YOU HAD BUILT AND DO HAVE SOMEWHAT OF A VISUALIZATION. BUT CAN YOU AND WUD YOU PLEASE POST SUM PIX, SO I CAN GET MY CAR BACK ON THE ROAD. I KNOW ONCE BEFORE WE HAVE HAD TO MAKE AND FABRICATE A TOOL FOR THE REAR BRAKES. WHY ARENT HYUNDAI RELEASING THESE TOOLS TO US SO WE DONT HAVE TO GO THRU THIS. IT HAS TAKEN ME 6 YRS TO FIND JUST A HAYNES MANUAL FOR THIS 2001 SONATA AND IT WAS BY PURE LUCK. ALSO...WHEN UNTIGHTNING THE NUT ARE WE GOING LEFTY LOOSY AS USUAL, OR IS THIS THING BACKWARDS?????
THANKS FOR ALL YOUR HELP...YOU CAN ALSO EMAIL ME DIRECT PIX OF THE TOOL AT......mariestanley40@yahoo.com................DU DE IM DESPERATE HERE...NEED HELP....CANT BE WITHOUT MY VEHICLE
Sonata Momma
mariestanley40@yahoo.com is offline   Reply With Quote Quick reply to this message
Old 02-27-2011, 07:13 PM   #5 (permalink)
jsinton's Avatar
Counter clockwise to loosen.
I never had a problem using the starter crank method. Did you try that? Always works easy for me, never seen it fail.
Old 04-16-2011, 03:11 AM   #6 (permalink)
mga123's Avatar
mga123
Hyundaistepdad;
I was wondering since I wanted to make a tool for my Hyundai Accent (since I cant Crankshaft get pulley nut off) does the Sonata Pulley look like Accent pulley see image
But I was afraid to use a piece of metal and three prongs to insert in between spokes of pulley
mga123 is offline   Reply With Quote Quick reply to this message
Old 04-26-2011, 02:09 AM   #7 (permalink)
mga123's Avatar
mga123
Again anyone have experience making pulley tool for 2002 accent?
I am afraid the "spokes" in the pulley will bend if I make a tool?
