Transmission Going Into Fail-safe Mode - Hyundai Forums : Hyundai Forum
Old 12-15-2005, 05:50 AM   #1 (permalink)
gajjitt
Hi all,
I wonder if anyone can help me here. My Sonata year 2000, has a frustrating problem in that the car will drive for some time (a few days) then suddenly it will shudder and the revs go up. At that point the auto trans is stuck in 3rd, heavy acceleration will not cause it to go to 2nd or 1st, and it will never go into 4th. If you stop and restart the car is fine for a while again.
Car is going into the dealer on Monday to have the codes read from the computer. The engine warning indicator never lights up.
Has anyone else had this, and what did they diagnose the problem as? Is it likely to be serious, the car drives very nicely until it happens. Wondering if this is something that happens and whether there is often a simple explanation which can be fixed quickly.
Any help will be welcome, I will tell you the outcome after the dealer has looked at it on Monday.
It has to start happening when my folks are about to embark on a visit from the UK to Australia for 3 weeks doesn't it?
Have a good weekend.
Thanks Paul
gajjitt is offline   Reply With Quote Quick reply to this message
Old 12-15-2005, 09:27 AM   #2 (permalink)
Luxury's Avatar
Luxury
I haven't heard of this problem on an 06 Sonata (yet), but it is somewhat common on the Cadillac Catera I used to drive. It is most likely an electrical problem, since it is intermittant and returns to normal operation. If it was a mechanical problem, it would not reset after turning the car off. It will probably be an easy diagnosis and fix, such as replacing a control module. Even though the CEL never came on, there are probably codes stored somewhere. Good luck and let us know how it turns out.
Luxury is offline   Reply With Quote Quick reply to this message
Old 12-16-2005, 01:13 PM   #3 (permalink)
madderhatter
Guest
Posts: n/a
I think this needs to be moved to a different forum - his car is a 2000.
Old 12-21-2005, 11:31 AM   #4 (permalink)
gajjitt
Hi my car is a 2000 Sonata.
FYI the dealer checked the codes and it reported that the input and output speed sensors were faulty. Some AU$700 later it's fixed and working!! A little painful in the pocket but happy with the outcome, the car is smooth and responsive again.
Hope this helps anyone else with a similar problem.
Cheers Paul
Old 12-21-2005, 11:33 AM   #5 (permalink)
gajjitt
Please tell me why the "Sonata" forum is the wrong place for a year 2000 Sonata?
Thanks Paul
Old 12-30-2005, 07:45 AM   #6 (permalink)
Madmax
Greg here
I have a 1999 Sonata and the output speed sensors has gone faulty x2
any idea way this is happening.
Why is this sensor so costly.
Madmax is offline   Reply With Quote Quick reply to this message
Old 03-04-2006, 05:47 PM   #7 (permalink)
TAKEMYEXWIFE
iM JUST GONNA SAY CHECK FOR AN OUTPUT SENSER ON THE TRANSMISSION. sOUNDS LIKE THAT. iF ITS GOT ONE THATS PROBABLY IT. ESP IF SPEEDOMETERE PROBLEMS ACCOMPANY IT. ALSO CHECK FOR AN INPUT SENSOR. ZGOOD LUCK
TAKEMYEXWIFE is offline   Reply With Quote Quick reply to this message
