Rear Speakers 2005 Sonata - Hyundai Forums : Hyundai Forum
Old 04-24-2005, 06:13 PM   #1 (permalink)
Bizzenn
Does anyone know the size of the rear speakers in the 05 sonata as I would like to upgrade them? Also, does anyone know what is a good wattage to use with a stock stereo. The smallest I've seen is 150 peak(watts)
Bizzenn is offline   Reply With Quote Quick reply to this message
Old 05-03-2005, 12:26 AM   #2 (permalink)
digital4fun
6 x 9
digital4fun is offline   Reply With Quote Quick reply to this message
Old 05-03-2005, 01:08 PM   #3 (permalink)
manhole
Originally posted by Bizzenn@Apr 24 2005, 03:13 PM
[b]Does anyone know the size of the rear speakers in the 05 sonata as I would like to upgrade them? Also, does anyone know what is a good wattage to use with a stock stereo. The smallest I've seen is 150 peak(watts)
[snapback]11458[/snapback]
Will you be running the stock stereo/amp to the speakers? It will power any 6x9's just fine. If I remember correctly the stock Hyundai speakers on the Sonata run at 2-ohm. Most aftermarket speakers you find will be 4-ohm, so it may be a good idea to replace the ones in the front also, otherwise your front speakers will be getting more power than the rears (2-ohm draws a heavier load).
manhole is offline   Reply With Quote Quick reply to this message
Old 05-05-2005, 09:10 PM   #4 (permalink)
Bizzenn
I will be running the stock system. Thank you for your help.
