2001 Sonata 2.5L Won't Start - Hyundai Forums : Hyundai Forum
Old 02-18-2013, 09:54 AM   #1 (permalink)
01 Sonata 2.5L
cjhamer is an unknown quantity at this point
Unhappy 2001 Sonata 2.5L Won't Start
This car was brought to the dealer for a no spark issue, parts replaced are: Crank sensor, cam sensor, ECU "Car still has no spark" Dealer says," Car has no power to coil pack and may need ignition coil pack module. Has anyone herd of this problem before? Dealer tells me it a $1,200 repair!
cjhamer is offline   Reply With Quote Quick reply to this message
Old 02-18-2013, 10:25 AM   #2 (permalink)
2003 2.7 Santa Fe 2001 3.0 Z3
Not to say your dealer is inept, but when the CPS goes bad because of insulation breakdown, the bare wires can take out one of the fuses. Sure hate to pay $1200, then find out it's a fuse.
Old 02-18-2013, 03:00 PM   #3 (permalink)
01 Sonata 2.5L
Thanks John, I'll check for blown fuse
Old 02-18-2013, 09:13 PM   #4 (permalink)
01 Sonata 2.5L
I went to the dealer today and they told me the car may need a Engine Control Module Wiring Relay! Does anyone know the location of this part? Thanks
Old 02-18-2013, 09:50 PM   #5 (permalink)
"Engine Control Module Wiring Relay!"
Never heard that one before..
Close to the Knueter thing ?
I be more interested in probing the legs of each of the fuses in the engine room junction block... bare exposed crank position wires will knock out 1 of the ECM/PCM fuses ---> BEEN THERE -- DONE THAT a few times..
Old 02-19-2013, 09:36 AM   #6 (permalink)
01 Sonata 2.5L
Thanks, SBR711
"Engine control Relay"
Old 02-28-2013, 12:36 PM   #7 (permalink)
01 Sonata 2.5L
I'm installing new ECM & Fuel injection Relays on Friday "no one had them in stock" Dealer told me 8-10Hr job, I removed them in under 2Hrs. Hope it does the trick but I'm doutful because they seem to check out good.
Old 02-28-2013, 11:32 PM   #8 (permalink)
Drives 2000 Hyundai Sonata
jlandry287 is an unknown quantity at this point
did this solve the problem?
jlandry287 is offline   Reply With Quote Quick reply to this message
Old 03-05-2013, 08:10 AM   #9 (permalink)
01 Sonata 2.5L
yippee, yahoo, replace the ECM & Fuel injection Relays same part #'s 39160-37100 and the car started!!! Thanks to everyone who helped and replayed to this post. Took me about 4hrs time, the Relays are right under the radio and removing the radio made it an easier job.
FYI; Don't try to remove the Relay brackets, just pop the old Relays off existing brackets and reuse old brackets.
Old 03-05-2013, 08:15 AM   #10 (permalink)
01 Sonata 2.5L
Thumbs up No Spark 2001 Sonata 2.5L V6
Yes, Thank God!
