Help!!!!! Timing issue - Hyundai Forums : Hyundai Forum
Old 12-20-2012, 07:22 PM   #1 (permalink)
crazyboutbbws's Avatar
Drive Sonata EF
crazyboutbbws is an unknown quantity at this point
Default Help!!!!! Timing issue
Been at it for a week now...my crankshaft position sensor on my 2002 Sonata needed to be replace (via check engine code). Did everything as listed in the many posts I have read...but car is hard to start and runs rough.
Question:
Should the factory TDC marks on the cam pulleys be in between the teeth or on the teeth (mine are in between hence the problem realigning.)
As you will see hopefully by my pics that I have all the TDC marks on the bottom half of the car set correctly according to what I have read. But it the cam pulleys that are giving me issues. I have gone so far as removing the valve cover and using a dowel to bring piston #1 to TDC and (please correct me if I am wrong) I tried setting the cam arms to correspond with the piston (ie rockers for the cam when the piston is in compression are not pushing down on the valve springs) I also have the intake rockers the exact opposite of the exhaust...meaning if the rocker for the intake is point at 9 o'clock then exhaust is point at 3 o'clock.
pix #1 TDC mark intake cam
pix #2 TDC mark exhaust cam
pix #3 TDC on crankshaft
pix #4 TDC on oil pump
Please assist...
THANKS IN ADVANCE
crazyboutbbws is offline   Reply With Quote
Old 12-26-2012, 05:51 PM   #2 (permalink)
MyKids04Sonata is an unknown quantity at this point
I believe there is more than one position that looks correct on the oil pump/balancer pulley... Check posts here and wait for others to reply also..
Dave
MyKids04Sonata is offline   Reply With Quote
Old 12-26-2012, 07:28 PM   #3 (permalink)
owns 2007 Elantra-- 2006 Santa Fe 3.5 GLS son has 2005 Elantra hatch
Last picture does't look right.
Boss on block should be centered between two teeth, not lined up with the edge of one.
Nasty job timing belts.
santa06 is offline   Reply With Quote
Old 12-26-2012, 11:09 PM   #4 (permalink)
Drive Sonata EF
Ok, will place between the teeth....thanks for your replies.
Old 12-27-2012, 10:44 PM   #5 (permalink)
Drives 2003 Sonata
DeadZombie is an unknown quantity at this point
did that fix your issue?
DeadZombie is offline   Reply With Quote
Old 01-03-2013, 11:27 AM   #6 (permalink)
Drive Sonata EF
Default Gonna try again today
Had family over for a couple of days...was good to walk away from it and come back minus upsetting emotions...I will post the progress.
Old 01-03-2013, 05:51 PM   #7 (permalink)
Drive Sonata EF
Just finished 12th attempt and don't know what to do the car still idles rough. As instructed I set the marks in between the teeth (see pics below) and the oil pump and crankshaft were set in the same position as in my very first post. I may have to bite the bullet and put it in the shop $$$$$<<OUCH!!!!!
Old 01-04-2013, 05:19 AM   #8 (permalink)
Drives 2003 Sonata
did you find the plug hole on the front of the engine, and made sure that the oil balance shaft was correct?
Old 01-04-2013, 05:25 AM   #9 (permalink)
Drives 2003 Sonata
also, did you make sure the balancing belt was intact, and they were lined up with the corresponding timing marks?
Old 01-07-2013, 02:37 PM   #10 (permalink)
Drive Sonata EF
@ DEADZOMBIE what is the plug whole you speak of? And yes all marks on the small timing belt sprocket as well as the crankshaft and oil pump mark are all aligned...I did not take a pic of the small timing belt area because I did not touch any of that.
