heater/ac blower not working 2002 Sonata GL - Hyundai Forums : Hyundai Forum
Old 11-14-2012, 09:35 PM   #1 (permalink)
Drives 2002 Sonata Drives 2001 Sonata
Lnfarr is an unknown quantity at this point
Send a message via AIM to Lnfarr
Default heater/ac blower not working 2002 Sonata GL
My blower settings are numbered 1 - 4. Recently the 1 setting stopped blowing. If I have it on 2,3 and 4 everything is good.
If I have it on 1 I can push on the knob and it will kick on. But lately that isn't working and the blower wont come on. Sometime it will come on in a second or two later, sometimes it will come on when i drive down the road. It doesn't seem to matter if its hot or cold out. I have replaced the blower motor and that worked for a few months now I think it might be in the control head. Any ideas?
If I replace it, how hard is it to remove and what is the procedure to get that control head out of the dash? I can't find any instructions anywhere to get it out!
Lnfarr is offline   Reply With Quote Quick reply to this message
Old 11-15-2012, 11:23 AM   #2 (permalink)
2003 2.7 Santa Fe 2001 3.0 Z3
I believe it's the switch itself that you are pushing on. I have read this is a common problem.
Old 11-15-2012, 11:53 AM   #3 (permalink)
thanks johnaauld i'll look into that, but my real problem is how to get to it. I am usually very good at figuring these things out but can for the life of me can't seem to figure out how to get to the unit in the dash. No screws that i can see and just do not want to just start prying things! the Hyundia site by Hyundai has nothing i can find on this other than electrical layouts.
i reread my question and i should clarify, the part of my statement that about not working on 1 was the start, it now doesn't work on any setting. sometimes come on and sometimes does,t as i explained. sorry for any confusion.
Old 11-15-2012, 05:21 PM   #4 (permalink)
Your switch is bad, you just need to replace it. Here is a link to do it:
Dash Remaval Out Of 2004 Sante Fe
Old 11-15-2012, 09:59 PM   #5 (permalink)
13SonataScott's Avatar
I had the same problem. A used switch module found on ebay fixed the problem. I paid $16. delivered.
13SonataScott is offline   Reply With Quote Quick reply to this message
Old 11-16-2012, 12:47 PM   #6 (permalink)
Thanks again johnaauld and lovemysantafe for the the removal link. But i have a 2002 Sonata and the ashtray is totally different and it's on a damper system to push in and out with an inset for the actual ashtray. It is part of the dash and no ovious way to take it out, so if there are 2 screws behind there i can't get to them. i just need to figure out where to start.
Old 11-16-2012, 02:02 PM   #7 (permalink)
Sorry, I pulled the santa fe dash removal link I had , not the sonata.
Old 11-17-2012, 06:25 PM   #8 (permalink)
doesn't anyone know how to get to get the control head out of the dash board on a 2002 sonata! please help.
Old 11-18-2012, 08:32 PM   #9 (permalink)
The Sonata's dash bezel snaps in with 4 tabs, one approximatley in each corner. That whole assembly from just above the hazard switch, to just above the ashtray is what I'm refering to. You can use a plastic automotive trim tool (google it if you don't know what they are) to help get in between the openings and pry it out, little by little. Once it is off in one piece (I don't believe there are any screws) you will see the 4 screws that hold the climate control module to the dash.
If you can't get the bezel off, you might consider going to a car audio installation shop and slipping them a $10-spot to get you started. It will take them about one minute.
Here is a link to an exploded view. See part #16:
Auto Parts - Parts.com, For Every Part of Your Life
Old 11-21-2012, 11:42 AM   #10 (permalink)
Thanks a bunch i finally got it out!
