LinkBack | Thread Tools |
#1 (permalink) |
Supplemental Restraint System (SRS) Air Bag System (ABS) (no cluster light on start up)
Just purchased a used 2002 Sonata GLS V6. Car has an SRS – Air Bags As I am now learning this car and reading the owners manual, I notice that the SRS light never illuminates when the vehicle first turns on. I checked the 2 fuses, they were ok. I have an OBD II – No codes – Assume a special scanner is required, correct? if so which type? In the meantime, I will check to see if the SRS control module is plugged in. Could be a cluster bulb. maybe bulb removed by previous owner ?? Any other suggestions before heading to the dealer for a scan? thanks. PS I understand this is a safety feature :-) jd |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) | |
2001 Trajet FO 2.7 GLS comfort
1996 Sonata Y3 3.0 GLS
OBD II has nothing to do with SRS. Nothing.
HiScan or GDS Quote:
unfortunately very likely to be on older pre-owned cars where people tend to take shortcuts to avoid expense ... probably the easiest to do |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
