P0304 computer code, cylinder 4 misfire - Hyundai Forums : Hyundai Forum
Old 10-25-2012, 04:25 PM   #1 (permalink)
2003 Sonata 2.4l
CompEd
Question P0304 computer code, cylinder 4 misfire
I have a P0304 computer code on my 2003 Sonata 2.4l. Error code indicated misfire on cylinder 4. I changed spark plugs about two months ago, so doubt it's a plug. Guess I need to change the coil pack and wire to that cylinder. Can anyone tell me the location of cylinder 4 when I face the front of the engine? Thank you. Comped
CompEd is offline   Reply With Quote Quick reply to this message
Old 10-25-2012, 05:31 PM   #2 (permalink)
2 and 4 have coil,, 1 and 3 is wire..
b
e
l --- 1 -- 2 -- 3 -- 4 ---> transmission
t
s
-------------------Radiator --------------- battery---------------
Old 10-25-2012, 07:05 PM   #3 (permalink)
2003 Sonata 2.4l
CompEd
Default Ignition coil pack
Not sure if misfire on cylinder 4 is being caused by defective ignition coil. I would assume if coil pack was bad, then cylinder 1 would also have a problem since wire from coil on cylinder four goes to cylinder 1, but only cylinder 4 misfires. I checked spark plug installed last month on cylinder 4, looks good. Can cylinder 1 still operate ok when #4 doesn't?
Old 10-26-2012, 02:41 AM   #4 (permalink)
Sonata 2000, 2.5L V6
SoNic67 is an unknown quantity at this point
It is a 'waste spark' ignition system. One of the cylinder sparks will be with reverse polarity compared to the other. Positive polarity spark is requiring higher voltage to 'spark' over the same gap. Both cylinders fire in the same time, but coil might be damaged only on one 'half' of the secondary winding.
What spark plug did you use? I think the best ones for Hyundai are NGK Laser Iridium.
SoNic67 is offline   Reply With Quote Quick reply to this message
Old 10-26-2012, 12:24 PM   #5 (permalink)
2003 Sonata 2.4l
CompEd
I replaced the coil packs, cleared error code, and all is well. Thanks to sbr711 and SoNic67 for their help!
Old 10-26-2012, 12:52 PM   #6 (permalink)
Good job!
