Random misfire on #2, 4 ,6 - Hyundai Forums : Hyundai Forum
Old 10-01-2012, 06:33 PM   #1 (permalink)
Nightstalker2160's Avatar
2004 Sonata, 2.7L auto 2005 Santa Fe, 2.7L auto
Nightstalker2160 is an unknown quantity at this point
Question Random misfire on #2, 4 ,6
My sonata 2.7L
It's running a little rough, check engine light comes on. I run the scanner and get a P302 code showing random misfire on the # 2, 4, 6 cylinder.
In the last 2 months I've replaced:
-Plugs
-Plug wires
-all three coil packs
-crank sensor
-cam sensor
I'm at a lose on where to go next. I just can't believe this is a spark problem with all those new parts.
Thanks in advance for any help,
2004 Sonata 2.7L, 155k miles
2005 Santa Fe 2.7L, 162K miles
Nightstalker2160 is offline   Reply With Quote Quick reply to this message
Old 10-03-2012, 11:13 PM   #2 (permalink)
MyKids04Sonata is an unknown quantity at this point
Low fuel pressure in rail causing injectors not to fire correctly. No/low fuel can cause misfires (or no fires). Plugs not correctly gapped (I believe that is .044) will cause mis-fires and out of the box they are usually wrong...
Tonight I replaced 4 Champion plugs (real junk) in my wife's Kia Spectra and found every single NGK pre-gapped plug wrong out of the box. A worn timing belt will cause timing to shift and plugs to fire at the wrong time. You made no mention of "if" the timing belt has ever been replaced and this is a critical item...If the belt slips or breaks you will trash the engine.
Dave
MyKids04Sonata is offline   Reply With Quote Quick reply to this message
Old 10-04-2012, 09:57 AM   #3 (permalink)
Dave
Thanks Dave,
I replaced the timing belt about 4 months ago at the same time I did the plugs and wires. I gapped the plugs when installing them, but did not use the NGKs. I've been wondering if that is my problem.
How do you check the pressure at the rails?
Old 10-04-2012, 10:41 PM   #4 (permalink)
SONATA EF 2.7l
JohnnyCakes is an unknown quantity at this point
Dave
I'm pretty sure that most NGK plugs do not come pre-gapped.
JohnnyCakes is offline   Reply With Quote Quick reply to this message
Old 10-05-2012, 12:47 AM   #5 (permalink)
cubawashere's Avatar
05 Accent 1.6 automatic POS
cubawashere is an unknown quantity at this point
I totally agree that Champion 4 are junk along with the Bosch 4s.... always stick to import parts when it comes to the imports.... Denso, NGK, BeckArnley are some of the import brands. I noticed you said you replaced 3 coil packs... make sure that these packs are also import part -it does make a huge difference or reuse the old packs which probably weren't bad to begin with. Also never have I seen 3 packs go all at the same time. They usually only go 1 at a time...2 is even kinda rare. Just mentioning for future use.
Good luck
cubawashere is offline   Reply With Quote Quick reply to this message
