2000 Sonata Cam Position Sensor Voltage - Hyundai Forums : Hyundai Forum
Old 06-06-2011, 12:46 AM   #1 (permalink)
mikebug63
I have a 2000 Sonata 2.4 that will not start. The manual states I should have battery voltage on pins 1 to ground and 3 to ground with the key in the start position and the cps connector disconnected from the sensor.
I have 12V on pin 1 to ground 5V on pin 2 to ground and no V on pin 3 to ground. It points to the MFI/ECM relay.
Has anyone ever had this relay go bad or the ECM?
mikebug63 is offline   Reply With Quote Quick reply to this message
Old 06-06-2011, 10:55 AM   #2 (permalink)
The sensor is wired for 12+,, 12-,, and feed back voltage of 5Volt when tested with connector unplugged from sensor.
We have scope function on Hi-Scan and watch square wave pattern & voltage of feed back signal from the sensor.
Old 06-06-2011, 02:33 PM   #3 (permalink)
mikebug63
Shouldn't I see the 12v + or - on pins 1 and 3 of the harness to ground with key in start position?
