How To Change A Throttle Position Sensor (tps) On Sonata 2001 - Hyundai Forums : Hyundai Forum
Old 03-27-2010, 10:56 AM   #1 (permalink)
plurnay
From previous post i heard that Sonata have problems with TPS sensor
So i think that my problem to...
I have a 2001 Sonata GL (4 cynlinder automatic)
i would like to replace myself but i dont know where its located
can someone tell me how to replace it thanks
plurnay is offline   Reply With Quote Quick reply to this message
Old 06-30-2010, 02:44 PM   #2 (permalink)
mjwoodruff
It's only two bolts and a plug.
To find it.. look on top toward the rear of your engine compartment. Find where the cables rotate the butterfly valve in the throttle body. On the opposite side of where the accelerator cables go into the throttle body is the Sensor..
If you have the replacement in your hand, it will help you identify what you need to remove..
mjwoodruff is offline   Reply With Quote Quick reply to this message
Old 06-30-2010, 04:38 PM   #3 (permalink)
QUOTE (plurnay @ Mar 27 2010, 10:56 AM)
Just a wild guess repplacement ????
In 7 yr of Hyundai, I do not recall replacing a TPS myself.... been scanned ? Got code(s) ? What you got ?
Tossing parts could compund what it is you trying to repair.. and can get costly at that.
Old 08-13-2010, 10:19 AM   #4 (permalink)
plurnay
I did check the code at two different place but not at a hyundai dealership and they both said
that it was something with the alternator??? they both told me that my alternator work fine?
But will look at it again very soon because its getting worst and i am already pushing my luck.
anyone know were i could found the sensor for cheap its like 600$ for the genuine hyundai and like 300$ for the aftermarket
its CRAZY!!!! that at the hyundai dealership
I paid less then that for the car !!!! LOL
thanks for you answers guys
Plurnay
Old 08-13-2010, 12:50 PM   #5 (permalink)
QUOTE (plurnay @ Aug 13 2010, 10:19 AM)
[b]This is at my Huundai dealership --> 35102-33100 / SENSOR ASSY-THROTTLE / $103.05 USD
Plurnay
Old 02-24-2013, 07:58 AM   #6 (permalink)
sonata 1995
arashflooyd is an unknown quantity at this point
Dear Sir
My car is Sonata model 1994 automatic with 4 cylinder.
I have a problem in THROTTLE POSITION SENSOR (TP SENSOR) adjustment.
I have done the adjustment just like the instructions that is mentioned in the Service manual.
I used a digital voltmeter to measure the voltage between connector 1 and 3.the voltage is 480-520 mV.
I also disconnected the negative connector of the battery for 30 seconds.But it didn’t work and the car is not idling well now.
I have RPM fluctuation while idling.in Idling mode the RPM is about 1100.
I would greatly appreciate if you help me about this case and tell me the correct way for TP SENSOR adjustment.
Best regards.
Arash Pourakbar
arashflooyd is offline   Reply With Quote Quick reply to this message
