Rear View Mirror Removal - Hyundai Forums : Hyundai Forum
Old 02-03-2008, 04:44 PM   #1 (permalink)
redhawks2
I want to put an aftermarket auto-dimming mirror in my '08 elantra and am wondering if anyone knows how to remove the existing mirror? It doesn't appear obvious to me and I don't want to start cranking and tugging on anything until I know what is the proper way.
Thanks for any info!
redhawks2 is offline   Reply With Quote Quick reply to this message
Old 02-23-2008, 12:57 AM   #2 (permalink)
kevallen
I was looking at adding a dimming, homelink, etc. mirror to my Elantra as well. I was having a rock chip repaired and I asked the technician how to remove the mirror. It is quite easy once you know how. Just hold on to the base of the mirror and push down towards the base of the windshield. The mirror slides out of the bottom of the mount pretty easily with steady pressure (it has a wire as a spring). The mounting base of the mirror remains on the windshield. I think you have to install a wedge mount below the OEM mount in order to install the new mirror. Let me know how it goes for you. My Elantra is an '07, but I am sure the mount hasn't changed.
kevallen is offline   Reply With Quote Quick reply to this message
Old 02-29-2008, 04:59 PM   #3 (permalink)
redhawks2
</span></span>
Old 05-02-2008, 02:45 PM   #4 (permalink)
Gus08
REPLACEMENT
1. Push the inside rear view mirror base down to remove the inside rear view mirror assembly after removing the mirror wire cover.
Mirror it adheres closely in the mirror base (A) and it separates while removing the mirror (.
Make sure the spring mounting bracket of the mirror not to be damaged.
2. Installation is the reverse of removal.
Gus08 is offline   Reply With Quote Quick reply to this message
Old 09-25-2010, 07:35 PM   #5 (permalink)
annendale
QUOTE (Gus08 @ May 2 2008, 02:45 PM)
REPLACEMENT
Gus08,
How do you remove the wire cover? Do you lift the edges of the cover next to the wind shield and pull?
annendale is offline   Reply With Quote Quick reply to this message
