Drivers door Lock - Hyundai Forums : Hyundai Forum
Old 12-08-2012, 10:20 PM   #1 (permalink)
dave1970
Default Drivers door Lock
My '07 Elantra wont open from the outside handle, and it also wont unlock when using the key fob. Is it possible I have a bad actuator?
dave1970 is offline   Reply With Quote Quick reply to this message
Old 12-09-2012, 10:13 AM   #2 (permalink)
2013 Gen Coupe 2.0T R-Spec
Duro5341 is an unknown quantity at this point
Does it open with a key?
Does it open when you unlock the door manually?
Duro
Duro5341 is offline   Reply With Quote Quick reply to this message
Old 12-10-2012, 07:16 PM   #3 (permalink)
dave1970
yes, the lock unlocks with a key, and it does unlock manually from the inside, just the door doesnt open from the outside handle. either the cable from the handle to the actuator is broken, or the actuator itself is bad, I'm guessing.
Old 12-11-2012, 08:41 AM   #4 (permalink)
Actuator is either frozen, or defective depending on your climate.....
Providing all the other locks are fine....the wiring is probably ok
Duro
Old 12-11-2012, 08:42 AM   #5 (permalink)
2004 Custom Tiburon
KoreanTinCan is an unknown quantity at this point
Did you check da battery in da fob?
KoreanTinCan is offline   Reply With Quote Quick reply to this message
Old 12-11-2012, 10:33 AM   #6 (permalink)
I taught that was basic enough, I assumed he tried the lock and unlock switches in the car to make sure of this
Duro
