06 Elantra Fuel MPG - Hyundai Forums : Hyundai Forum
Old 11-18-2011, 02:48 AM   #1 (permalink)
Drives 06 Elantra GLS
sma1141 is an unknown quantity at this point
Default 06 Elantra Fuel MPG
I have an 06 Elantra, I have had it for two years now. As the miles have racked up, the MPG has gotten worse and worse and worse. Some tanks I am down to 13-15 MPG. When I got it in 2009, it was doing 35 on the highway. It has had all of its scheduled maintenance, and then more. The timing belt is new, the ignition cylinder is new, the spark plugs and their wires are new, the air filter is new, the tires are new and in balance, and the air filter and oil are new. All of the normal things that can lead to bad mileage are new and not causing issues. I have taken it to Hyundai, and they can not even explain what is causing this. There are no sensors out, no warning lights, and nothing registers on the computer as being broken. I am absolutely at a loss as to why the MPG is so awful. I do a large amount of city driving, and I have even lightened up on acceleration, and use the brake pedal as little as possible. I don't accelerate above 2500 RPM's now. However, none of this has made a difference, the gas guzzling keeps getting worse and worse. I am a college student, I live on a budget, and the gas is eating into other parts of the budget. Also, the valves have begun clacking and clanking, it is like driving a Sherman tank now. I am not sure why they are getting so noisy. Again, Hyundai had no explanation for this. There is a difference between wear and tear, and poorly built parts. Finally, this 2.0L engine in the 06 is a unique engine. From the research I have done, it is the only 2.0L they have used in the Elantra. In the model year update after mine, they went back to the 1.8 or 1.6L engine. My 02 had the 1.8L and it was a really good little car. I wonder if there is just an inherent problem to the 2.0 and that is why they dropped it from production. All I know, is I would appreciate any suggestions that might help this problem, and the awful clacking of the valves.
sma1141 is offline   Reply With Quote Quick reply to this message
Old 11-18-2011, 03:13 AM   #2 (permalink)
Default Clarification
One the 5th generation Elantra's in the U.S. they have gone back to the engines under 2.0L. The engine in the 06/07 is not in used any longer.
Old 11-19-2011, 11:37 AM   #3 (permalink)
2008 Elantra GLS
alanb is an unknown quantity at this point
Isn't the 2006 Elantra in the XD series? I wonder if you might get more responses in the XD forum.
alanb is offline   Reply With Quote Quick reply to this message
