Clunking In Elantra - Hyundai Forums : Hyundai Forum
Old 07-06-2010, 08:06 AM   #1 (permalink)
highwayman_nl
does anyone one else have a slight clunking sound in the front of their elantra, only noticed it yesterday and is only there at start offs and is there in forward and reverse motions. may be more of a click like sound at times as well
cheers
Mel
highwayman_nl is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 12:11 PM   #2 (permalink)
Link (s) at front is soft spot, especially if hit a lot of bumps... the small ball/socket on the link gets loose and you get a clunk sound over bumps... drive carefully down the road, and rock the steering wheel left/right and make the body rock real hard, see if noisey..
Old 07-08-2010, 08:00 AM   #3 (permalink)
fegue2's Avatar
'99 Accent GSI apple red/ 09 Elantra GL, moonlight blue/ 2012 Elantra GL Harbor grey,2014 Santa Fe S
fegue2
QUOTE (highwayman_nl @ Jul 6 2010, 08:06 AM)
cheers
Mel
Hi,well i got that problem before,and the dealership diagnosed and replaced the front end links in both sides under warranty(45 mins job),you can hear that noise over bumps ,potholes or irregular roads,pretty annoying,also you will feel a slight free play in your steering wheel and sound in your suspension (the link that is failing)when you are not in motion and you try to move it one side to the other,then the noise progress over time in one side ,then the other and in my case it was very loud.(My personal experience,that could be different in other circunstances).
Cheers
Phil.
fegue2 is offline   Reply With Quote Quick reply to this message
Old 07-08-2010, 08:30 AM   #4 (permalink)
highwayman_nl
Phil i have to noise you are refering to, however i also have aa slight knocking in the front end when i put it into either drive or reverse and when i first accererate, and then it isnt heard anymore until i stop and accerate again, got an appointment next week at the dealer so i will update of the outcome, oh and by the way i still have that annoying right rear rattle that they assured me would be fixed i May month
cheers
Mel
Old 07-11-2010, 08:13 AM   #5 (permalink)
fegue2's Avatar
fegue2
QUOTE (highwayman_nl @ Jul 8 2010, 07:30 AM)
cheers
Mel
Mel,do you have the noise when you put the car or i should say when you select
''Drive'' or "reverse"?,then that might be something different,please keep us updated.
Phil.
Old 07-13-2010, 06:49 PM   #6 (permalink)
Don67's Avatar
Sounds like the Santa Fe 2G forum here.
My 2008 SF had a front-end clunking over bumps (bad stabilizer link) and a click/clunk when shifting gears (plastic washer on axle). Both fixed promptly under warranty. See your dealer.
Don67 is online now   Reply With Quote Quick reply to this message
Old 07-17-2010, 09:59 AM   #7 (permalink)
kerribear_84
I have been having issues with my 2007 elantra also with these funny noises. I have now had both left and right sway bar link's replaced and also all 4 strut mount dust covers sprayed with urethane because they were lose. This has still not fixed the problem. I get this loud clunking when turning corners and the dealer has yet to figure out what the problem is.
kerribear_84 is offline   Reply With Quote Quick reply to this message
Old 07-17-2010, 01:15 PM   #8 (permalink)
jeff3820
It helps in all cases to not only tell the forum the year of your vehicle but also the amount of miles/km and if the vehicle is driven mainly in the city, highway, or a combination of both. With enough mileage this could be most any front end part...struts, bushings, just about anything.
Any competent dealer that hears a front end noise should be able to find it...just a case of looking for the part with excess play.
jeff3820 is offline   Reply With Quote Quick reply to this message
Old 07-29-2010, 12:28 PM   #9 (permalink)
GoodOmens's Avatar
GoodOmens
If you have a 2009 you might be covered under the attached service bulletin - Front Strut noise.
Requires replacement with a new bumper stopper and is covered under warranty.
GoodOmens is offline   Reply With Quote Quick reply to this message
Old 12-11-2010, 10:57 PM   #10 (permalink)
1stjimmy
QUOTE (jeff3820 @ Jul 17 2010, 12:15 PM)
Thanks, this is true information.
1stjimmy is offline   Reply With Quote Quick reply to this message
