Oxygen Sensor Bank 1 Sensor 1 Tiburon Gt 2.7 - Hyundai Forums : Hyundai Forum
Old 06-26-2009, 12:38 PM   #1 (permalink)
cmarshal
I need to replace the oxygen sensor at bank 1 sensor 1. I have looked at the location of the sensor at hmaservice, but I am unable to locate it where they show it. Does someone have a better description or pictures of where it is located? Thanks in advance!!
cmarshal is offline   Reply With Quote Quick reply to this message
Old 05-20-2010, 12:30 PM   #2 (permalink)
tuscanigt75
Hey there. I just got done doing that myself. Bank one is the side of the engine closest to the firewall. If you stand overlooking the engine from the driver's side fender, you can barely see it down there. It is upstream, so that means before the cat. converter. You have to work from the bottom, so get the right front in the air and secure with jackstands. Bank 1 sensor1 = upstream, driver's side. Attaching some pics but I just got home and the engine is still a lil hot to get in there with some good pics...P.s.: Save some heartache and get a special box wrench at your local auto parts store as this sensor is in a tight spot and normal tools can't get the leverage....give it a try, but if not definitely invest in getting that tool....
tuscanigt75 is offline   Reply With Quote Quick reply to this message
Old 05-20-2010, 12:55 PM   #3 (permalink)
Before you go killimg yourself and wasting money,,, What is the code you currently have ?
There is program #155 for 2005-2006 Ox logic if you have not had PCM updated..
The program is to address the 0130/0150 codes... may have jibberish in the update to cover other stuff too...
Old 03-08-2011, 06:58 PM   #4 (permalink)
shark_ink34
hey guys. i have an 03 tiburon tuscani. i scanned the computer due to the check engine light being on. it says bank 2 sensor 1? idk where that is. any help? when i start the car you can smell gas and i noticed my gas milage droppped and horsepower dropped.
another conceren is the maf also came up on the scanner. it will stall if i try pulling it out of 1 or reverese? i need help with that as well. i love my car so any help is grateful!!
shark_ink34 is offline   Reply With Quote Quick reply to this message
Old 09-24-2011, 06:12 PM   #5 (permalink)
vicky63857 is on a distinguished road
what else can make the code read for an o2 sensor when both has been changed
vicky63857 is offline   Reply With Quote Quick reply to this message
Old 09-25-2011, 04:35 PM   #6 (permalink)
Hyundaiownersclub
Various air leaks,misfire and lpg
HYUNDAI TECHNICIAN BASED IN ESSEX UK. ALL HYUNDAI REPAIRS/MODS UNDERTAKEN INCL ENGINE/GEARBOXES Hi Scan and GDS equipment... www.hyundaiownersclub.co.uk / www.essex-tech.co.uk
Hyundaiownersclub is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 09:59 PM   #7 (permalink)
what is lpg? as i said before both 02 has been changed. i have a fuel fiter to change to see if that helps. sometimes you can feel it cutting in and out and every once in awhile it will die but always starts right back up. its an 05 tib 4 cyl if that helps any
Old 04-19-2012, 01:50 PM   #8 (permalink)
2005 HYUNDAI TIBURON GT
CHELITA09 is an unknown quantity at this point
Smile 02 sensors
I also have a tiburon gt 05, i have 4 02 sensors tho, anyway i can get step by step pics?
CHELITA09 is offline   Reply With Quote Quick reply to this message
Old 04-19-2012, 03:16 PM   #9 (permalink)
Why are we looking to replace ox sensors ?
B1 has a pre cat and post cat sensor - bulkhead side
B2 has a pre cat and post cat sensor - radiator side
Couple codes do not require sensor replacement,, PCM program instead.
Old 05-08-2012, 11:46 PM   #10 (permalink)
2012 Tucson GLS AWD 2013 Elantra GLS Sedan
kookie_guy
On the V6, if you wash your engine and get water all over the oxygen sensor/connector it will throw a code for the oxygen sensor. Did it on my 2003 tib with the 2.7L, and also did it with my 2007 tucson with the 2.7L. So if you washed your engine and got it, that's why. Just have a shop reset it and you should be ok. If it throws the code again, then you got a problem.
kookie_guy is offline   Reply With Quote Quick reply to this message
