Flywheel - Hyundai Forums : Hyundai Forum
Old 02-07-2008, 11:44 PM   #1 (permalink)
rattfink
does anyone know if you have a dual mass flywheel currently on the vehicle and replace it with a single mass flywheel, if this is a bad thing?
2004 Hyundai Tiburon
2.7L V6
rattfink is offline   Reply With Quote Quick reply to this message
Old 02-08-2008, 12:43 PM   #2 (permalink)
terkar
Check on newtiburons.com---I'm sure the answer is there somewhere.
terkar is offline   Reply With Quote Quick reply to this message
Old 02-09-2008, 04:34 PM   #3 (permalink)
Hyundaiownersclub
The dual mass is garbage and a single mass is much better.
HYUNDAI TECHNICIAN BASED IN ESSEX UK. ALL HYUNDAI REPAIRS/MODS UNDERTAKEN INCL ENGINE/GEARBOXES Hi Scan and GDS equipment... www.hyundaiownersclub.co.uk / www.essex-tech.co.uk
Hyundaiownersclub is offline   Reply With Quote Quick reply to this message
Old 02-12-2008, 10:18 AM   #4 (permalink)
mfp
mfp's Avatar
mfp
Here is a link to a group-buy for clutch/flywheel combos :
http://www.newtiburon.com/forums/showthread.php?t=123604
edit : adding link for slave cylinder delay-valve removal DIY :
http://www.newtiburon.com/forums/showthread.php?t=1962
http://www.cardomain.com/ride/3806779/1 2000 Mustang GT Convertible http://www.cardomain.com/ride/777995/1 04 Tuscani
mfp is offline   Reply With Quote Quick reply to this message
Old 04-01-2008, 03:32 PM   #5 (permalink)
darkcloud2266111's Avatar
darkcloud2266111
you dont want to go from a dual mass setup to a single mass because of the space between the clutch and flywheel is going to increase and cause chattering bucking of the tranny
darkcloud2266111 is offline   Reply With Quote Quick reply to this message
Old 05-16-2008, 04:23 PM   #6 (permalink)
april5112
You should not switch from a dual mass flywheel to a single mass flywheel, I had this done to my Tiburon not knowing the dealership that changed out my clutch was doing this. 4 months later I had to have my tranny rebuilt by a Hyundai dealership due to it shattered the bearings in my transmission and was causing my car not to shift into gears.
april5112 is offline   Reply With Quote Quick reply to this message
