08 Azera Heater Blos Cold On Driver Side - Hyundai Forums : Hyundai Forum
Old 04-05-2011, 02:44 PM   #1 (permalink)
82corvette
My 08 Azera blows cold air out the drivers side vent when everything on the right sides blows heat. If I set drivers side 88 degrees it blows some warm air. I changed the cabin filter and that did not help. Any ideas?
82corvette is offline   Reply With Quote Quick reply to this message
Old 04-17-2011, 01:23 AM   #2 (permalink)
txskyhawk
QUOTE (82corvette @ Apr 5 2011, 01:44 PM)
Took my 2008 Azera (bought it used last October) in this week for the same problem only with the A/C.....cold air on the on the passenger side but not the drivers side. Dealer ordered a part - some sort of valve - which will be installed next week. Dealer claims to never have seen this before. They said the same thing about the lights dimming during decelleration. (they replaced battery cable and added ground points with no effect on dimming). I worry about the cause of the dimming but have decided to live with it. Will post result of the air flow distribution valve (or whatever it's called) next week.
txskyhawk is offline   Reply With Quote Quick reply to this message
Old 04-25-2011, 09:01 PM   #3 (permalink)
txskyhawk
The part is called an Air Inlet Actuator (part# 97124-3K000). Apparently there is both a driver's side and a passenger side actuator. Installed this morning....works fine now.
Old 05-11-2011, 07:48 AM   #4 (permalink)
Quick99Si
For future reference, I just wanted to add that I had the same problem with the passenger side being stuck on heater mode. I removed the actuator and moved the lever manually which allowed the passenger side to have both heating and A/C. I'm heading out to buy a new actuator if the current one is a confirmed failure. List price is $85.
Attached is a picture of the passenger side actuator. It's located relatively high in the dash on the passenger side. To get to it, you would have to remove the glovebox, lower air duct (single screw with head facing to floor at the blower motor), and glovebox frame. The FSM doesn't call to remove the frame but it sure made things a lot easier. This is only if you're out of warranty like I am
Quick99Si is offline   Reply With Quote Quick reply to this message
Old 05-11-2011, 03:55 PM   #5 (permalink)
Quick99Si
It's actually called a temperature control actuator I guess. There are two of these while there is only one "mode control actuator" (on the driver's side, responsible for toggling recirc air on and off). It's a bit confusing since the TEMP ACTUATOR part number is 97124-xxxx while the MODE ACTUATOR part number is 97154-xxxx. The Hyndai parts guys were less than useful with this. Anyway, I applied 12v across pins 3 and 4 and nothing happened, so this actuar is definitely shot. Now onto finding a place to buy it...
INSPECTION
TEMPERATURE CONTROL ACTUATOR(PASSENGER’S)1. Verify the temperature control actuator operates to the hot position when connecting 12V to the terminal 3 and grounding terminal 4.
Verify that the temperture control actuator operates to the cool position when connecting in the reverse.
2. Check the voltage between terminals 5 and 6.
Specification
Door position
Voltage (5-6)
Error detecting
Max. cooling
0.3 ± 0.15V
Low voltage :
0.1V or less
Max. heating
4.7 ± 0.15V
High voltage :
4.9V or more
It will feedback current position of actuator to controls.
TEMPERATURE CONTROL ACTUATOR(DRIVER’S)1. Verify the temperature control actuator operates to the hot position when connecting 12V to the terminal 3 and grounding terminal 4.
Specification
Door position
Voltage (5-6)
Error detecting
Max. cooling
0.3 ± 0.15V
Low voltage :
0.1V or less
Max. heating
4.7 ± 0.15V
High voltage :
4.9V or more
REPLACEMENT
TEMPERATURE CONTROL ACTUATOR(PASSENGER’S)1. Remove the glove box (Refer to BD group).
2. Disconnect the temperature control actuator connector (A) after removing the air duct.
3. Loosen the mounting screw and then remove the temperature control actuator (.
4. Installation is the reverse order of removal.
TEMPERATURE CONTROL ACTUATOR(DRIVER’S)1. Disconnect the negative (-) battery terminal.
2. Disconnect the connector © of temperature control actuator.
3. Loosen the mounting screw and then remove the temperature control actuator(D).
Old 12-23-2012, 06:17 PM   #6 (permalink)
2009 Azera 3.8 2005 Jeep Wrangler X 1988 K1500 Silverado 1995 Country Coach Magna
Relative
Just experienced the same problem on wife's '09 Azera. Driver's side blows cold only. Removed the driver's Temperature Control Actuator and tested it. Worked OK. However, did notice that these two pins were slightly smaller than the other 3 pins. Gave them a slight twist to increase the tension when the plug was put back on and it worked just fine.
Mike
Relative is offline   Reply With Quote Quick reply to this message
Old 01-07-2013, 08:20 PM   #7 (permalink)
Relative
Red face Correction
Correction:
After a couple of days, it failed again. Pulled the actuator out again and this time I opened it up to see exactly how it operated. Nothing but a DC motor with several gears to gear down the rotation of the actuator portion and a potentiometer on the final gear to indicate position by the voltage passed.
Put 12V to the DC motor in both directions. One way operated full speed and quietly. The other direction was interesting. The motor hesitated, slowly started and eventually got to full speed. The motor also sounded like it was grinding in that direction. Obviously, the motor was bad. Each time I reversed the leads after the first test, it operated at full speed, but with the grinding in one of the directions.
I suspect on my previous attempt to test it, the test itself cleared up the bind in the motor for a short while and gave a false indication to me that the connector was probably the problem.
It might be possible to replace the DC motor if one is so inclined.
Purchased a new actuator and it has been working just fine now for several days in temps less than zero. Until I obtained the new actuator, a bungee cord was used to keep the two levers flipped to give full heat to the interior on the driver's side.
Mike
