Replacement Dvd/gps/tv/bluetooth Unit - Hyundai Forums : Hyundai Forum
Old 02-02-2009, 05:46 AM   #1 (permalink)
glospete's Avatar
Sante Fe 2.2 Premium CRDi Auto, 5 seater
glospete
Default Replacement Dvd/gps/tv/bluetooth Unit
I have a 2006 CDX with the 2.2 diesel engine and I thought some of you may be interested in the results of finding and fitting a replacement radio unit. I spent some days on the Internet (I'm retired so time is no problem for me!). I eventually found a company in China who had a range of units which fitted individual cars as "plug and play" with no wire cutting involved. I had the choice between an RDS unit complete with DVD and GPS or another one (WD6001) which had a better specification including iPod control:
• 6.2 inch in-dash Two Din TFT touch screen (480x234)
• 3D graphic menu
• Steering control function to match with the car's steering wheel control
• Built-in AM/FM radio; 30 stations storable (but non-RDS)
• Built-in analogue TV (no use for me in the West Country from May this year!)
• Automatic PAL/NTSC
• DVD/CD/MP3 CD player
• Built-in Bluetooth for connection of mobile phone
• Built-in GPS satellite navigation (runs from the micro SD card) – can have navigation and music at the same time (but see my comments later)
• USB interface (for connection of USB thumb drives or USB drives)
• Micro SD card slot on front face
• One channel AUX Video input, two channel Video output
• Rear view parking camera input
• 45W x 4 MAX power output
• iPod connector
• Dimmer function for night driving mode
I decided on the latter as I had already decided to purchase a DAB radio for the car which would make the RDS feature largely redundant. More on that later!
I guess my major concern was the removal of the dashboard trim to access the current radio - however I shouldn't have worried as a forum member helpfully explained the procedure carefully and even sent me an instruction sheet!
So to ordering the unit. I purchased it direct from the manufacturer (www.szwaywell.com) - I was able to have all my concerns satisfied in advance as I had a MSN Messenger type communication with them for some days before I committed. They were extremely helpful and explained that there would be absolutely no wires to cut as the ISO/DIN connection to the current radio simply unplugs and the new one plugs into the same block, and that all the steering wheel controls would operate as before.
The cost of the unit was 360 USDollars plus $70 for shipping to UK. I ordered it and they shipped it at 1pm on a Saturday (UK time). I was given a DHL link to see it as it moved to Hong Kong Airport, then Heathrow Airport, then the DHL centre in the East Midlands, then my local DHL centre in Exeter. And I could hardly believe it when it was delivered at 10.00am on the Monday morning, less than 36 hours after it was shipped. I thought I had beaten HM Customs & Excise but they sent a bill for the duty and tax at a later date!
I have attached some pictures showing the unit as it was delivered and during and after fitting.
Fitting - I began by removing the 2 screws holding the small glove box above the clock so that I could then see the old radio. I then followed the instructions from the forum member to unclip the dashboard trim and it went exactly as one would hope with no damage being inflicted on the "wood" and plastic trim. Then it was just a case of unscrewing the bolts holding the old radio, unclipping the power/connection block and then offering up the new unit. This was simple and in no time (well, maybe an hour as I went VERY slowly) the new unit was fitted and I tested the functions before I clipped the dashboard trim back in place.
Am I pleased with the result? From an aesthetic viewpoint it is as close to perfect as is possible to get - the silver colour matches the existing trim, even the blue lighting colour is a close match to the existing blue lighting of the other buttons. Everyone who has seen it has remarked that it looks as though it was designed by Hyundai as an original fitment.
How does it perform? Well the biggest problem I had was the GPS satnav and I thought I'd made a mistake buying it at first! As I said earlier you can choose which GPS satnav system you want supplied (the unit runs WINCE 5 and any system compatible with that works OK - in theory!). It actually runs the software which is on the micro SD card. I opted for TomTom as this was the satnav system I had on my current dashtop unit. Well that was a big mistake! It transpired that it is impossible to set the Regional settings in TomTom so the local time (time of arrival etc) is wrong. Doh! So more searching of Forums (especially www.gpsunderground.com) and I found that a more suitable system would be iGO8 and all the software is available on the site together with maps of the world. I have installed v8.3.2 and that includes maps of UK dated November 2008 and I even have speed camera warnings (£17 p.a. at www.pocketgpsworld.com) and Text To Speech ability as well.
What are the problems? It may be my installation but I have a very slight whine when the unit is on (and there is volume on the unit). It is not speed dependent i.e. it does not get louder or change if I rev the engine. It is not noticeable when you are driving – only standing still. I have booked it in the see a "radio doctor" in Exeter next week to see if he can solve it – perhaps it may be something as simple (LOL) as a choke.
The other comment is not a problem as such but when I am using the satnav and the radio for example, I would prefer the satnav screen to be visible all the time and the radio sound be replaced by the satnav instructions. As it is I get the radio screen all the time and the radio is muted and the satnav instructions and the satnav screen appear only when a turning or something occurs. I'm not sure I've explained that very well but I hope you can understand? It's not a problem and I have reported it to the manufacturer to see if a firmware upgrade could alter it. If not, c'est la vie!
Other than that I am delighted with the Waywell unit and can highly recommend it (no connection with the manufacturer!).
Once it was all fitted I then decided to fit the DAB radio and the reversing camera. I purchased the PURE Highway radio and made use of the aux. input connection in the Waywell rather than relying on the FM transmission to send the signal from the Highway. That way you get a solid signal. I fitted the unit itself into the box between the front seats and even using the arm supplied it fits perfectly. The beauty of fitting it there is that it is never on display in the car. I purchased a proper DAB magnetic aerial and the reception is perfect so long as it is not a dead DAB area. I find it better than RDS as it has all the benefits of DAB i.e. constant buffering of programmes so you can rewind live radio or indeed pause live radio to catch any traffic reports or news bulletins you may have missed.
Fitting the reversing camera was rather more tricky as you have to run 2 wires from the camera – one signal and one power wire. I tapped into the reversing light power wire in the tailgate and carefully ran the wires forward. It is hardly noticeable. I fitted the camera just above the number plate.
Santa Fe 2.2 Premium CRDi Auto - 5 Seat; Carbon Grey
ordered: 8 March 2010; delivered: 29 July 2010
glospete is offline   Reply With Quote
Old 02-02-2009, 01:01 PM   #2 (permalink)
antoniobb
Thanks for the detailed explanation.
I have also purchased the very same unit (i did pay a little more: $520 with 2day shipping to USA) but included a rear view camera and a TV antena at www.tradesolution.hk)
I must say I agree with everything said in this first post, there is a perfect match in color and size and makes the unit look as factory original. I was able to get my gps to work with a Garmin XT system, (which took about 2 days to make it work) but at the end, it works like a charm.
I installed the rear view camera inside the just below the third brake light to avoid getting it robbed.
I also hooked up the bluetooth system, with the only complaint that since the microphone is "built in" the person at the other side of the conversation has a hard time hearing me.. (maybe it is a faulty bluetooth connection?? anyone else has experienced this?)
About the high pitched noise... it is also present on my unit, and I know this should be mainly because of a bad ground cable but it is so low that you may barely notice it.
I will be more than happy to reply to any questions that may arise from other SF owners.
by the way, mine is a 2008, CDRI 2.2
I will rate installation as very easy, and the camera installation as a moderate diffictuly (specially getting the reverse light signal)
antoniobb is offline   Reply With Quote
Old 02-02-2009, 01:20 PM   #3 (permalink)
Meagain
Wow. Thanks so much for taking the time to post all that detail for us. Very nice/helpful.
I'm a bit confused as to which unit is which when you refer to having 2 choices there. This looks different from yours yet lists the model no. as WD6001. Has different buttons than yours.
I also found this one somewhere. http://s306.photobucket.com/albums/nn265/s...ntafecamera.jpg
May I ask a stupid question? This unit merely controls the stereo. It has no effect on the 605w Infinity unit and doesn't change sound quality or watts, etc. Right?
Meagain is offline   Reply With Quote
Old 02-02-2009, 04:05 PM   #4 (permalink)
rantipole
Hi Glospete
I have exactly the same system as you, also with Igo8 3.3 running. I went through the same problems with TomTom, and I have tried Route 66. I was a bit disappointed to begin with, but Igo8, which i had never heard of before, is really good. I echo all of your comments, especially that it would be better if you could have the radio on while you look at the map screen. Please let us know if you have any luck with the firmware request. My only complaint is that I paid more than you! i got mine from Ebay. I got the radio removal instructions from Hyundai USA. It was a lot easier to fit than I expected.
rantipole is offline   Reply With Quote
Old 02-02-2009, 05:31 PM   #5 (permalink)
antoniobb
My SF does not come with the infinity system but I do have the original amplifier below the passengers seat, and the system controls everything. This is a plug and play device, no hazzle..
I have a question for those who already own the system: do you experience a low microphone volume when using the bluetooth system (meaning the other side of the conversation is not hearing you well... or belives you are inside a deep hole!)
about the different units, I believe both are much the same, It looks as if the picture posted by Meagain is somewhat an older device, as it does not come with the "joystick"...
Old 02-03-2009, 09:49 AM   #6 (permalink)
glospete's Avatar
glospete
QUOTE (Meagain @ Feb 2 2009, 06:20 PM)
Sorry Meagain not to make this clear! Originally I had a choice between 2 units - one (I forget the number) and the one I bought WD6001. I now see that Waywell no longer offer any other unit for the Santa Fe except WD6001. This is the one in all the pictures. Hope that clears that up! The unit you linked to is NOT the same Waywell unit as I have.
The unit replaces the stereo so I'm not sure what you are asking. In the UK the Santa Fe comes with an amplifier under the driver's seat (Infinity unit not available) and the WD6001 links with that amplifier and also the steering wheeel controls operate as before.
Old 02-03-2009, 09:57 AM   #7 (permalink)
glospete's Avatar
glospete
QUOTE (antoniobb @ Feb 2 2009, 10:31 PM)
I'm told that the quality of the sound via Bluetooth is fine (I've never heard it as I'm always in the car!) but I do find that I need to increase the volume to 6 or 7 to hear the other person on their phone.
Old 02-03-2009, 12:25 PM   #8 (permalink)
rantipole
QUOTE (antoniobb @ Feb 2 2009, 05:31 PM)
Bluetooth volume is a bit quiet for me too. Your description sums it up nicely.
Old 02-03-2009, 01:23 PM   #9 (permalink)
bubba g
Thanks for the great writeup glospete. I think I'm gonna order one from the manufacturer too, great price and looks. I'll be heading to china for vacation next week, hopefully they can ship it to my hotel so I can save a lil on the shipping.
bubba g is offline   Reply With Quote
Old 02-03-2009, 04:00 PM   #10 (permalink)
eman6880
Looks like a nice unit but does it support Sat Radio?
If it does not do the Sat radio I think I will have to continue using stock radio with my Garmin
eman6880 is offline   Reply With Quote
