LinkBack | Thread Tools |
| Sponsored Links | |||
Advertisement | |||
#12 (permalink) | |
#13 (permalink) | |
#15 (permalink) | |
QUOTE (UniR @ Dec 1 2007, 10:19 PM)
I just created an account at hyundai forum to say thank you for this. |
#16 (permalink) | |
QUOTE (maseace @ Jan 26 2008, 03:11 PM)
headlights should be adjusted so that the headlights don't affect oncoming drivers - use either a headlight aiming chart or have your headlights adjusted by someone who has a headlight aiming machine so that they are adjusted to consider oncoming drivers
2010 Santa Fe Highlander 2.2l R-Series CRDi Diesel |
#17 (permalink) |
question: my new 2011 hyunda santa fe SE V6 for adjustment of high and low beams:
Is the low beams adjusted separately than the high beams? Reason being is I drove my new santa fe at night first time this weekend and the low beams are perfect, but the high beams are a smidge too high. The high beams on the front and sides of the vehicle directly in front are completely dark, no light at all unless you are a shorter driver say 5' or so. Is there a separate adjustment for low and high beams? |
#18 (permalink) |
I would also like to know if the high beam can be adjusted on my 2006 model, used it in the dark for the first time at the weekend. The dip beam was a bit too low and when i put on the high beam the lights hit the ground within the pattern of the dip beam rather than almost straight in front.
Wondering if the previous owner found the dips so poor he adjusted the high beams down so he could drive with all 4 on to see where he was going. I fitted a 4300K HID kit to the dip when I got the car, nice clear light pattern on the road with two yellow high beam spots in the middle of it! |
#19 (permalink) |
2008 Hyundai Sante Fe GLS
2005 Volvo S40
"the manual doesn't cover it well."
My manual doesn't cover it AT ALL! Thanks so much for the help. I'm going to go downstairs and adjust my headlights. Thanks again! |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
