Hyundai Forums : Hyundai Forum (http://www.hyundai-forums.com/index.php)
-   CM (2007-2012) Santa Fe (http://www.hyundai-forums.com/187-cm-2007-2012-santa-fe/)
-   -   Hyundia spIII subsutute (http://www.hyundai-forums.com/187-cm-2007-2012-santa-fe/178129-hyundia-spiii-subsutute.html)
dharvey1020 08-24-2013 11:46 PM
I am going to do a tranny fluid change in my 2008 Santa Fe. I am wondering if anyone has had some luck with a subsutute to the hyundia brand fluid. 9.16 a quart is a bit pricey.
Zoom49 08-25-2013 12:36 AM
Check here, good write up. http://www.hyundai-forums.com/187-cm...ly-easy-4.html Used Castrol multi import. $60 for the 3 gallons required.
Ruperts Trooper 08-25-2013 03:53 AM
Hyundai SPH-IV, Kia SP-III, SPH-IV or Mitsubishi Diamond SP-III are all compatible with Hyundai SP-III.
The SPH-IV is the better specification used in the 2010-on 6-speed autoboxes but backwards compatible.
Various 3rd party ATF is compatible with SP-III.
johnaauld 08-25-2013 10:02 AM
I've used Castrol-multi import since 80k miles on my 03 santa fe(now have 127k). The first year I changed out all 11 quarts(two pan dumps), but I have gone to a single pan dump yearly. I use moble 1 extended performance so I can do my oil changes the same time every year- costs around $75 to do both.
dharvey1020 08-25-2013 03:24 PM
I want thank every one posting in this thread and this board. I did the fluid change today. Used the castrol import. Huge difference in the car. This must have been what it was like when it was new. Lets just hope it keeps running this good. Thanks again, Dave
canderson 08-26-2013 04:52 PM
Can you elaborate on that? What seemed to be the issue before the fluid change, and how did it feel differently afterward? I've only got 74K miles on mine, but no sense that it shifts oddly -- same as always.
