LinkBack | Thread Tools |
#1 (permalink) |
I noticed that the reverse gear ratio is much higher than 1st in forward is. Why is that?
The last couple of times we had a lot of snow the Santa Fe seems to have lots of torque to go forward through it from a stop, but when I reverse into my driveway through the heavy snow the city snow plow has pushed up I really have to give the Santa Fe a lot of throttle before it is able to push through. Like 75% throttle. Traction is great, but it almost seems underpowered in reverse. |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
Drives; 2011 SantaFe 2.2crdi
I don't think so!! The higher the ratio the more power required to move the vehicle. Try moving off on a push bike if you're in too high a gear! That's why 1st gear is a low ratio.
If it ain't bust don't fix it! Think first then use a big hammer. If it won't move hit it harder! OldSantaFeMan |
#5 (permalink) |
2009 SF LTD
First Gear Ratio (:1) 4.21
Second Gear Ratio (:1) 2.64 Third Gear Ratio (:1) 1.80 Fourth Gear Ratio (:1) 1.39 Fifth Gear Ratio (:1) 1.00 Sixth Gear Ratio (:1) 0.77 Reverse Ratio (:1) 3.39 Transfer Case Gear Ratio (:1), High 1.00 ------------------------------------------------ As the reverse ratio is lower than first gear - the 75% more power you observed is quite close to the difference of ~80% |
#6 (permalink) |
Thajks for the replies and thanks for the gear ratios. But I am a little confused. It looks to me like the gear ratio for reverse is between the gear ratios for 1st and 2nd at 3.39, right? So reverse is a higher gear than first? Not lower.
Is there any reason manufactures do that? Is it just to be able to drve at a higher speed in reverse? Scott |
#7 (permalink) | |
Power is power, regardless of the gearing - gearing only multiplies the torque.
RT 2011 Santa Fe 2.2CRDi Premium 7-seat automatic (often being tailgated by a 3307 lb travel trailer) |
#8 (permalink) | |
We used to get people putting in a higher ratio diff and then wondering why the vehicle went slower because the engine had insufficient power to pull the higher gear!
#10 (permalink) |
2009 SF LTD
Hmm, well
Not here to argue about the ground principle of the mechanics. Some clarification is needed: The lower the dear --> the higher the gear ratio. The lower the gear --> the easier to move the car. Most people with manual transmissions gobble the concept easier. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
