Fuel Sending unit.. intermittent? sbr771 input please - Hyundai Forums : Hyundai Forum
Old 01-17-2013, 04:00 PM   #1 (permalink)
Pinto_Siftbean's Avatar
2008 Santa Fe LTD 3.3L with 6 way power mudflaps and fuel injected synchronizers
Pinto_Siftbean
Default Fuel Sending unit.. intermittent? sbr771 input please
1/2 tank of fuel.. then empty.. then 1/2 tank again after a while. Has anyone seen this? Know it can be an issue on the 08's.
Also, will this intermittent issue throw a code? Can hardly wait to talk to my dealer if it doesn't...
The Liver is Evil and must be punished.
Pinto_Siftbean is offline   Reply With Quote
Old 01-17-2013, 04:46 PM   #2 (permalink)
Sonata 2012 SE TURBO 2008 Santa Fe Limited
reus49 is an unknown quantity at this point
I had to replace our sending unit on our 2008!
reus49 is offline   Reply With Quote
Old 01-17-2013, 07:20 PM   #3 (permalink)
rowemesp
Had the same symptoms on our 08, plus we had the MIL illuminate. Resulted in the warranty replacement of the two sending units in the tank.
rowemesp is offline   Reply With Quote
Old 01-20-2013, 12:25 AM   #4 (permalink)
rpmking's Avatar
2008 Santa Fe SE AWD ~ me 2007 Sonata SE ~ wife
rpmking
Faulty circut boards on the sending units + CEL, get both replaced under warranty asap. Make sure the gas tank is near empty before dropping off at the dealer.
rpmking is offline   Reply With Quote
Old 01-20-2013, 07:10 AM   #5 (permalink)
Pinto_Siftbean
Never saw it put the CEL on.. that's why I was wondering if it will store a code.
Old 01-20-2013, 11:22 AM   #6 (permalink)
canderson's Avatar
2008 Limited
Scan it. Intermittents will set codes, too.
FWIW, the codes for sensor A are
P0461 (not sensing level change = stuck float or connection issue),
0462 (voltage abnormally low = bad sensor or connection issue),
0463 (voltage too high = bad sensor or connection issue) and
0464 (voltage is jumping around too much = stuck float or connection issue),
and the corresponding codes for sensor B are P2065, 2066, 2067 and 2068.
To answer you other question .. there should be an engine light as well if the problem persists for '2 driving cycles'.
These problems are nearly always on the sender side, but if there aren't any codes being set, then it is possible that you have a rather unusual problem on the gauge end of the equation.
canderson is offline   Reply With Quote
Old 01-20-2013, 12:41 PM   #7 (permalink)
Erratic fuel level... replace both sender with the new style part.. common on the shelf part for us..
Canderson pretty well nailed it, scan it and see if related code(s) hiding in the PCM.
Have fuel level down a good bit, less fuel to splash around while in service.
Working currently with bummed shop tiny laptop, my home 'puter on fritz currently, tower out to in-law' younger brother for repair (independent IT company).. so I am not on board as much currently
sbr711 is offline   Reply With Quote
Old 01-20-2013, 01:05 PM   #8 (permalink)
Drives a 2007 sante fe
olott81 is an unknown quantity at this point
Question, my car is out of warranty. Can I do this myself. Is there an extension on this repair if a car is out of warranty.
olott81 is offline   Reply With Quote
Old 01-20-2013, 01:24 PM   #9 (permalink)
No warranty extension that I know of, unless you got some extended service contract..
Do it yourself,,,, you can get seats out and expose the the top of the units, but you need the HYUNDAI tool to grab the retaining rings to rotate and release modules from tank to remove and replace sender attached to side of module
Old 01-20-2013, 01:49 PM   #10 (permalink)
canderson's Avatar
2008 Limited
Given the (relatively) high failure rate, it would certainly be nice, but no ... it's the luck of the draw.
We've got a couple of threads around here (try searching 'sender' and 'fuel' together) that talk about various experiences with both dealer and DIY changes of these units. sbr's advice about the tool is worth heeding. We've seen a few folks try to bang off the rings with a hammer and slot blade, but nearly everything I've read here about people trying to do it that way is accompanied by words that get turned into asterisks by the board software You'll also find that many have had issues about properly resealing and avoiding spillage during the R&R that leaves a fuel smell from the back seat, so use caution.
