LinkBack | Thread Tools |
#1 (permalink) |
Drives Toyota Yaris
Hello,
2011 Santa Fe with 3.5L V6 and AWD, 38000 Kms: Very recent work (last month or so) - new battery (old one had a bad cell), brake light switch and for a repair of the seat adjustment bar (not sure what it is called). The most recent oil change was done by me in November and I have only put about 1600 kms on it since. I put 5W20 Castrol Syntec and a made in Korea WIX filter. I fill the oil to just a hair below the top dot on the dip stick. I torque everything properly. OIL LIGHT PROBLEM: When I was driving home from work this evening, I had to brake a little harder than I normally would when I was turning into the back lane (about 8 houses from my house). I thought I saw the oil light come on, but I wasn't sure. I continued down the lane when someone walked out in front of me and I had to brake again. This time, the oil light did come on for sure and then went off when I took the brakes off. It was -20 C outside, so I continued to my house which was now 4 homes away. I braked to go into my (heated!) garage and the light came on again as soon as I touched the brakes. I decided to let the car sit for an hour to get an accurate reading on the dip stick. I checked it and the level read exactly where I had filled it - just a touch below the top dot. I took the oil filter out to check that it was still seated properly and was not obviously clogged. It looked just fine. No signs of any leaks in the engine compartment or under the vehicle. I decided to take the car out again to go around the block - maybe not a great idea. The light didn't come on again when I braked until the vehicle had warmed up again. What could the problem be? I guess I need to take it in, but I start work at 7 AM and my wife is on maternity leave and she needs a car tomorrow. So, this means me taking the Yaris is out. She can't take the Santa Fe to the dealer with my infant son and so I guess I have to get it towed. This is bullshit. This POS has been in the shop several times since November. I can just feel it nickle and dime-ing me once warrenty is through. |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
At first I was thinking hard braking = oil sloshing combined with low oil causing the sump to go empty. But now you are saying that level is good.
May be a faulty oil pressure switch. Let the dealer take a look. Sent from my iPhone using AutoGuide.com App |
#3 (permalink) | |
Drives Toyota Yaris
#4 (permalink) |
2008 Limited
I had the same thought at Pare John at first, but then another thought came to mind -- more from the 'old days' of things like the 'anti-stall dashpot' on a carb. By any chance are your engine RPMs dropping VERY low in response to the fast braking? Have you noted that?
#5 (permalink) | |
Drives Toyota Yaris
#6 (permalink) |
2008 Limited
Easy enough to check in a parking lot some evening when there's not much of anybody around. Get running and hit the brakes hard, then watch both the tach and the oil light. If the engine is very nearly stalling due to braking, the low RPM could explain the light.
#7 (permalink) |
2011 Sonata GLS,
2010 Mazda CX-9 AWD
i'd start by swapping out the filter and see if that solves the problem, a visual inspection won't tell you much unless things are grossly out of whack. failing that, on to the stealer...
Wise men still seek Him! |
#8 (permalink) |
Drives 2011 Sportage EX AWD techno orange
IMO, that filter is questionable?
By the way, a Wix filter is made by Fram, They're all I've used in the past, but after quite a bit of reading lately, the general consensus is they're garbage! I would replace that filter with a Hyundai one, I read they're better then most, plus your warrantee is safe.
Previous vehicles a 2010 Tucson GLS AWD Kiwi green, 2005 Tucson LX V6 AWD Nautical Blue 2002 Santa Fe V6 Crystal Blue |
#9 (permalink) |
2008 Limited
Watch carefully on 3rd party filters. At least some brands are importing the 'yellow' colored filters from Korea (check the country of origin on the package) that are absolutely indistinguishable from the OEM filter... probably coming out of the same factory.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
