Vibration when idling - heater hose against the firewall? - Hyundai Forums : Hyundai Forum
Old 01-01-2013, 08:29 PM   #1 (permalink)
Drives Santa Fe 2009 E-Series 2.2 CRDi turbo diesel
kiwijas is an unknown quantity at this point
Default Vibration when idling - heater hose against the firewall?
i have a 2.2 crdi 2009 santa fe and when my foots off the gas pedal it has this strange vibrating hum noise that comes and goes - it doesnt matter if its in Park or Neutral.
you can only hear it inside the cab so im thinking maybe its something up against the firewall but i cant see what
any suggestions on what it might be?
kiwijas is offline   Reply With Quote
Old 01-01-2013, 09:24 PM   #2 (permalink)
Don67's Avatar
Welcome to the forum
Not much information to go on here. Pebbles in the exhaust shields can cause resonance, usually variable as you rev the throttle. Garden hose gets rid of that. Otherwise it could be any number of random interior trim parts vibrating with the engine... especially common with 4-cylinder models. Unless it is especially loud and/or easily-localized, you might have to get used to it.
Good luck, and please post the solution if you find it.
Don67 is online now   Reply With Quote
Old 01-03-2013, 01:25 AM   #3 (permalink)
thanks for the reply. its definitely coming from within the engine bay, almost like a spinning belt or bearing. ill keep digging.
Old 01-03-2013, 10:14 AM   #4 (permalink)
2003 2.7 Santa Fe 2001 3.0 Z3
Take a good look at your pulleys. Not sure about your model, but there have been a few crank pulleys that have separation issues.
johnaauld is offline   Reply With Quote
