LinkBack | Thread Tools |
#1 (permalink) |
Drives Santa FE Trail
Hi There,
Newbie here.... please don't crusify me! lol...I've got a quick one for you guys... just wonderin' if anyone has tried to put on spacers on the hubs. I think, putting them on will give the santy a wider stance (obviously) which will make it a bit better (aesthetically - flush with the wheel well or about 10 mm out). Also, would putting spacers on ruin the ride/suspension? And would it void my warranty? Lastly, has anyone seen an actual santy with the VEGA body kit on. I'm seriously considering the VEGA body kit to be installed as a birthday gift to myself! Would it void my warranty if I install it? Thanks heaps... Last edited by rvillam; 01-01-2013 at 01:54 PM. Reason: change thread title |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
Spacers and longer bolts are a cheap but not recommended alternative to changing the wheel rims to get less inset, lower ET number.
Altering the track, by either method, will affect the ride and handling, probably adversely. This would void the warranty in many countries, you'd have to check with Hyundai Australia.
RT 2011 Santa Fe 2.2CRDi Premium 7-seat automatic (often being tailgated by a 3307 lb travel trailer) |
#5 (permalink) |
Drives 2010 Santa Fe GLS 3.5 AWD - 2002 Saturn - 2006 Chrysler 300C
3mm spacers work on most cars without adverse effects. Anything above that and it's hub centric spacers and longer bolts. Really wide applications require short hub bolts and hub centric spacers with their own bolts for the wheels.
Having said that, none of this is a recommendation, just information. Do it right and get new wheels with the correct offset then while you're at it, add a bit more rubber. |
#6 (permalink) |
Santa Fe owners are notoriously pragmatic, so take this with a grain of salt. But what's the point of spending money to make a Hyundai look better at the potential expense of mechanical reliability? Isn't that what BMWs are for?
#7 (permalink) |
^^There are also some owners who just can't resist screwing around with their cars to dfferentiate them from the "masses". It's called the "mod disease" and yes I'm affilicted.
#8 (permalink) |
2008 Limited
Given the engineering time spent trying to get the steering and suspension geometry "right" for best driving experience, it seems a shame to artificially create large offsets in the wheels that ruin a very nice bit of engineering effort just for the 'looks'.
#10 (permalink) |
2008 Limited
The same sorts of problems are going to be created with spacers, rims with unusual offsets, or anything else that moves those tires towards the outside of the fenders. There's no "best path" when that path starts moving the offset significantly.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
