LinkBack | Thread Tools |
#1 (permalink) |
i hope someone can point me in the right direction i was driving my van with my wife in our car behinde me and noticed the the front lights on our santa fe looked different?
i pulled over and flaged her down saying you have not got your light on properly, only to discover she had yet they look different, so i put on the side lights and had the red back lights come on but no front lights? any ideas what this can be |
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
Drives: 2010 Santa Fe FWD 6-speed
1st position should turn on your tail lights and quarter lights (4 corners)
2nd position will turn on your headlights
Stef 2010 Santa Fe GL FWD, 6 Speed Manual Harbor Gray - "Lumpy" |
#4 (permalink) |
Santa Fe 2.2 CRDi 2011 Premium man/7st
I'm guessing you are in the uk with a late'06 or early '07 car.
You should never have any lights on at the front with none at the rear, and vice versa ( except brake lights) Sounds like a blown fuse or busted relay. |
#5 (permalink) |
2012 VW Touareg
It's a lousy picture but this section of the headlight should light up with the lights turned on in any position:
![]() And is the clear section under the main and dipped light bulbs in the photo below: If you reach behind the headlight the sidelight bulbs are the closest to the wing on each side, and although awkward they are a quarter turn to remove. Turn the socket not the wire. If you have a meter you can test to see if the bulb socket is getting power, or just get yourself some replacement w5w/wedge type bulbs and try them. |
#7 (permalink) |
2012 VW Touareg
I always assumed the orange section lit up as marker lights? Looking on google it seems odd but are the indicators are used instead? I really quite liked the illuminated brow styling.
I'd be tempted to take the headlight out and see if there isn't a blanking plate/bung that you could remove to make them work. Must be a relatively simple mod? Not sure I'd fancy opening up the units but this is effective: Daylight Running Lights for Hyundai Sta Fe DRL Philippines - 5732910 These units are off the shelf but not cheap: Hyundai Santa Fe Headlights - Black (06>) |
#8 (permalink) | |
Drives 2012 Santa Fe GL 3.5 AWD
Sent from my iPhone using AutoGuide.com App |
#9 (permalink) |
http://dx.com/p/t10-8w-720lm-4-led-w...rd-lamp-154838
I actually ordered 8 of these, 2 for my new reverse lights, and 6 extra to sell to a local led dealer, but they would be perfect to throw in there once I make sure heat won't be a problem. By the way, anyone needing led bulbs should look through DX.com 's list it's amazing and dirt cheap with free shipping, tho it can sometimes take 3-4 weeks to get your stuff ![]() Sent from my iPhone using AutoGuide.com App |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
