Water came from sun roof - Page 2 - Hyundai Forums : Hyundai Forum
Old 11-20-2012, 04:00 PM   #11 (permalink)
2013 Santa Fe Sport 2.0T Serrano Red Premium and Technology Packages 2001 Sonata GLS loaded
grandpaswagon is an unknown quantity at this point
Originally Posted by Don67 View Post
Don't waste your time trying to get the dealer to "fix" a sunroof that spits a few drops under high-pressure car washes. The rubber seals are designed to cushion the glass and block most rainfall, but that's all. They are not designed to resist compression under 3,000 psi of water pressure. That's why all factory sunroofs come with an inner drain channel.
@reus49: Kudos on the creative modification. But as a warning to others, padding up the rubber seals can sometimes create more leaks than it solves, and/or put added strain on the motor. I would only do this if there was a serious gap that was causing problems during normal rainfall, but in that case you'd have a valid warranty claim.
+1 Everything he said is good. And I will repeat my previous post............. don't use those high pressure touchless car washes.
grandpaswagon is offline   Reply With Quote
Old 11-20-2012, 08:48 PM   #12 (permalink)
Santa fe 2012 3.5L V6 limited with Nav
Jcbc323 is an unknown quantity at this point
After second though and digest all yours advise and comment..
I desired not go back to the dealer cause afraid that even get worse then before after they FIX it for me.
In winter time, it is not possible not to do the touchless car wash to clean the ice and salt at the buttom of the car, so next time when I do this I wil put a cloth or towel in between the water tray and the rubber seal to absorb the alien water
Jcbc323 is offline   Reply With Quote
Old 11-25-2012, 06:04 PM   #13 (permalink)
rpmking's Avatar
2008 Santa Fe SE AWD ~ me 2007 Sonata SE ~ wife
rpmking
I solved this problem by not opting for a sunroof...
rpmking is offline   Reply With Quote
