Headlights don't work but High-beams do - Hyundai Forums : Hyundai Forum
Old 10-05-2012, 10:05 PM   #1 (permalink)
ptw016
Default Headlights don't work but High-beams do
The normal lo-beams won't turn on no matter what I do, but the brights still work. The bulbs are good, the fuses are good. I've tested and changed those. They're good.
What's the issue? Is it a relay? Anyone had this problem? '08 Santa Fe
ptw016 is offline   Reply With Quote Quick reply to this message
Old 10-05-2012, 11:22 PM   #2 (permalink)
Do you have day time running lights ; they have a separate module that is tied into the head lights.
Were the headlight bulbs tested with a meter for continuity on the filament , visual not good enough IMO.
santa06 is offline   Reply With Quote Quick reply to this message
Old 10-05-2012, 11:42 PM   #3 (permalink)
ptw016
I replaced them with new bulbs. Didn't work.
Pretty sure I don't have running lights. Just the GLS basics
Old 10-06-2012, 01:35 AM   #4 (permalink)
canderson's Avatar
2008 Limited
Try swapping relays between low and high beam. In the box under the hood.
Old 10-06-2012, 01:57 PM   #5 (permalink)
ptw016
I swapped out different relay fuses and tried the spare fuse and horn fuse for the lights and got nothing to work. High beam relay fuse(s) are rated at different current levels, but I tried one of those too. It looks like the low beam circuits just aren't getting any power.
I'm guess I'm just worried that if I take it somewhere (particularly the dealer) they'll make me replace some big electrical part instead of truly diagnosis a lose wire here or whatever it is.
Old 10-06-2012, 08:21 PM   #6 (permalink)
canderson's Avatar
2008 Limited
If you're able to deal with a wiring diagram, the one attached applies to your '08 model. This and a meter should make you dangerous enough to locate the problem.
Old 10-06-2012, 09:01 PM   #7 (permalink)
AlpineRyder's Avatar
Drives 2012 Santa fe 3.5 AWD W/ Nav, 2010 Elantra
AlpineRyder is an unknown quantity at this point
The relays are only good for 10,000-15,000 clicks. A click is counted x2 every time you turn your lights on. One on and one off. Try replacing the relay
AlpineRyder is offline   Reply With Quote Quick reply to this message
Old 10-11-2012, 11:08 PM   #8 (permalink)
Two separate relays would have to die simultaneously for both low beams not to work ; doen't seem that likely.
Nice diagram from Canderson , I think you need to look at the output from the BCM module , the brown orange wire.
Old 10-12-2012, 11:43 AM   #9 (permalink)
2012 Santa Fe 4wd 2.4L, 1980 Mercedes Benz W123 2.8E, 2005 Renault Symbol 1.6
polarfest is an unknown quantity at this point
corrosion at the relay sockets? fried relay? did you measure any voltage at the bulb plugs?
polarfest is offline   Reply With Quote Quick reply to this message
