Oem headlight bulb replacement - Hyundai Forums : Hyundai Forum
Old 06-27-2012, 11:42 AM   #1 (permalink)
dhavi4226
Default Oem headlight bulb replacement
2008 Santa Fe. Removed 2 bolts and 1 nut as shown in manual. cleared the clip at the bottom outboard corner. What else am I missing? I'm still Unable to remove the headlight bucket. It will only come out about an inch or so then feels like something else is holding on. Thanks for any advice.
dhavi4226 is offline   Reply With Quote
Old 06-27-2012, 12:08 PM   #2 (permalink)
I don't have skinny hands but I've changed all 4 bulbs, ie main and dip, on mine without removing the headlights.
RT
2011 Santa Fe 2.2CRDi Premium 7-seat automatic (often being tailgated by a 3307 lb travel trailer)
Ruperts Trooper is offline   Reply With Quote
Old 06-27-2012, 12:50 PM   #3 (permalink)
Sonata 2012 SE TURBO 2008 Santa Fe Limited
reus49 is an unknown quantity at this point
I dont think you really need to remove headlight to just get the bulbs out!
reus49 is online now   Reply With Quote
Old 06-27-2012, 12:59 PM   #4 (permalink)
You do, according to Hyundai - but it can be done without.
RT
Old 06-27-2012, 01:26 PM   #5 (permalink)
pare_john's Avatar
Looking at my '12 it seems like it can be done with the headlights left in place.
pare_john is offline   Reply With Quote
Old 06-27-2012, 10:51 PM   #6 (permalink)
mikenigro
Cool Oem headlight bulb replacement
I did everything you describe on my 07 and experienced the same problem. But the bucket does come out, believe me. 0n the lower back side of the bucket (fender side of the vehicle) there is a male rubber grommet that locks into a female rubber piece on the fender well. You can't see it from the front of the vehicle or the from the top looking down under the hood. But it's there and you'll see it once you're able to work the bucket out. That's what's holding the bucket up and with a little muscle it will break loose.
mikenigro is offline   Reply With Quote
Old 06-28-2012, 03:03 AM   #7 (permalink)
dhavi4226
Thanks to all that responded. I'll give it another go this weekend. I thought there was a grommet as described. Didn't want to break anything though. Thought about trying to soak the area with some soapy water and perhaps free thins up a bit. Anyhow thanks again.
Old 06-28-2012, 09:16 PM   #8 (permalink)
2012 Santa Fe 4wd 2.4L, 1980 Mercedes Benz W123 2.8E, 2005 Renault Symbol 1.6
polarfest is an unknown quantity at this point
check this guide Hyundai Santa Fe Headlight Bulbs Replacement Guide - Low Beam, High Beam & Turn Signal Light Bulbs - 2007 To 2012 Model Years - Picture Illustrated Automotive Maintenance Instructions
polarfest is offline   Reply With Quote
Old 06-30-2012, 08:04 PM   #9 (permalink)
PEACEKEEPER's Avatar
Drives a 2007 Santa FE
PEACEKEEPER is an unknown quantity at this point
I just replaced all of mine a couple of months ago in my 08. I'm 6'4" 300 Lb so I have mitts. I did it without removing the lights. It's wasn't a snap but it only took about 20 min. Taking them out will make it much easier to replace the lights but you now have to take the light out and then put it back. I didn't want to do that so I had to tough it out and use my patience. Good luck either way. The upside of removing the light is you will now know how to do it when you dive further into the front end.
PEACEKEEPER is offline   Reply With Quote
