Changing the license plate bulb on a 2010??? - Hyundai Forums : Hyundai Forum
Old 06-26-2012, 07:28 AM   #1 (permalink)
2010 Hyundai Santa Fe GLS
houndog1178 is on a distinguished road
Default Changing the license plate bulb on a 2010???
Does anyone know how to change this bulb on a 2010?? It is more then just taking out the 2 screws on the outside of the light.
houndog1178 is offline   Reply With Quote
Old 06-26-2012, 08:00 AM   #2 (permalink)
Sonata 2012 SE TURBO 2008 Santa Fe Limited
reus49 is an unknown quantity at this point
After taking out the screws, pop out the plastic cover with a thin flat screw driver.
reus49 is offline   Reply With Quote
Old 06-26-2012, 08:02 AM   #3 (permalink)
2007 Hyundai Santa Fe SE 1966 Porsche 912 1920 Ford Model T Roadster
deesperson
I changed one of mine on a 2007 3.3. The bulb was a push-in blade type. I was surprised to see that the screws were almost rusted away. I am planning on changing the screws to stainless.
deesperson is offline   Reply With Quote
Old 06-26-2012, 04:17 PM   #4 (permalink)
Does not work that easy. Was told by dealership that you have to remove the entire rear hatch panel???
Old 06-26-2012, 06:05 PM   #5 (permalink)
Drives 2010 Santa Fe SE V6 AWD
maltz
What? No, you take out the two screws, then the plastic housing pops out easily with a flathead screwdriver. Then you rotate the socket to remove it from the plastic housing and then the bulb just pulls out. As deesperson said, it's a push-in blade kind of bulb.
I've done it myself, so I know first-hand. I don't know what your dealer was thinking, unless maybe they were just trying to get the labor to do it for you. I can't think of any lights that require a whole panel to be removed, except maybe the lights in the bottom corner of the door? Not even sure about that, but the manual says that they're not user-replaceable.
maltz is offline   Reply With Quote
Old 06-26-2012, 08:22 PM   #6 (permalink)
2012 Santa Fe 4wd 2.4L, 1980 Mercedes Benz W123 2.8E, 2005 Renault Symbol 1.6
polarfest is an unknown quantity at this point
I changed them last week for LED's since the rearview camera has some LED bulb as well, and the procedure is just as described above, couple of screws, pop the lid and you are home free!
polarfest is offline   Reply With Quote
Old 06-27-2012, 11:19 AM   #7 (permalink)
ok, will try it on friday when I have time and post my results. Thanks!
Old 02-15-2013, 10:15 AM   #8 (permalink)
Drives 2009 Hyundai Santa Fe Drive 2013 Hyundai Elantra
kfossett is an unknown quantity at this point
You can do it both ways as mentioned. It's easier to pop out the panel. Make sure you put a piece of tape on the flat head screw driver when popping out the license plate light panel. I'm about to change my license plate lights on my 09 Santa Fe this weekend.
kfossett is offline   Reply With Quote
Old 03-27-2013, 07:47 PM   #9 (permalink)
HavoK's Avatar
Drives '07 Santa Fe V6 3.3 GL and '09 Mazda 3 GX
HavoK is an unknown quantity at this point
I need to replace these on my 2007. What is the bulb size for the license plate lights?
HavoK is offline   Reply With Quote
Old 03-28-2013, 02:13 AM   #10 (permalink)
canderson's Avatar
2008 Limited
Per owner's manual, W2.1 x 9.5D, 5W. That translates to a #168 from most manufacturers.
canderson is offline   Reply With Quote
