2012 Sante Fe Bluetooth question - Hyundai Forums : Hyundai Forum
Old 10-25-2011, 04:25 PM   #1 (permalink)
2012 Hyundai Sante Fe AWD 14 GLS 2005 Hyundai Accent
bens33 is an unknown quantity at this point
Default 2012 Sante Fe Bluetooth question
I have 2 phones paired to my new Sante Fe. I figured out how to set my wife's phone as the primary phone so that when we both get in the car her phone connects to Bluetooth. The question I have is when I get into the car alone the Bluetooth does not automatically connect to my phone. I have to manually connect it. Is there a way to set it up so that when I get in the car alone Bluetooth automatically connect to my phone? Thank you.
bens33 is offline   Reply With Quote Quick reply to this message
Old 10-25-2011, 11:21 PM   #2 (permalink)
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
If you don't have navigation, follow these instructions:
> Press 'SETUP'
> Rotate to 'PHONE' and select it.
> Rotate to 'PRIORITY' and select that, then choose the phone you would like it to pair to. That phone will then be marked by a [P] and will be the first to be paired in the presence of both phones.
Hope this helps and welcome!
- Andrew
Titanium Gray / Gray Leather
lovemysantafe is online now   Reply With Quote Quick reply to this message
Old 11-11-2011, 10:34 PM   #3 (permalink)
2010 Santa Fe GLS
garza83r is an unknown quantity at this point
> Press 'SETUP'
I didn't know that. But I was going to say just turn off the BT from your phone. Like on my Evo I have a switch to turn it off/on whenever I feel like it.
garza83r is offline   Reply With Quote Quick reply to this message
Old 03-04-2014, 06:02 PM   #4 (permalink)
rlbryant40 is an unknown quantity at this point
Just purchased 2012 santa fe but not able to sync phone. Followed instructions but still will not work. When trying to pair phone device says santafe does not allow me to put mine in. Please can someone help me with this.
rlbryant40 is offline   Reply With Quote Quick reply to this message
Old 03-04-2014, 06:28 PM   #5 (permalink)
crackinhedz's Avatar
Drives 2012 Santa Fe (Limited)
crackinhedz is an unknown quantity at this point
Did you put your phone into discover mode? (probably under the phone bluetooth settings)
crackinhedz is offline   Reply With Quote Quick reply to this message
