LinkBack | Thread Tools |
#1 (permalink) |
Scared me half to death. Yesterday while driving (coming down a very steep hill), I applied brakes softly as I had to make a right turn in about 300 feet. I noticed I had no braking power and was unable to turn the car so I coasted into a nearby parking lot. All the lights were on the car but it seemed dead. I turned the key off and made a call to see if my spouse could come and get me. While talking to him, I turned the car on and it started and off I drove with no further problems.
This is horrible. I can't imagine if I were on the interstate at 70 miles an hour. I was debating calling Hyundai and having them tow it but closest Hyundai garage is a 2+ hour drive. When I called to make an appointment with Hyundai service they acted like it has never happened before. Now I am stuck driving it on the interstate for over 2 hours and believe me I am very nervous. Any ideas? |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Drives: 2010 Santa Fe FWD 6-speed
How much gas was in the tank? If you were close to empty going down a "very steep hill" and slowing down, that would push the gas totally to the front of the tank. Don't know where the pickup is, but that's what comes to mind at the moment. Engine starved for gas. If it was nowhere near empty, we'll have to keep on digging.
Stef 2010 Santa Fe GL FWD, 6 Speed Manual Harbor Gray - "Lumpy" |
#3 (permalink) |
Drives: 2012 Elantra Limited
Oh, boy. Welcome to the club of Santa Fe owners whose cars stall randomly. You are member number two.
First comes the bad news; mine has done it five times in the last year and has never once thrown a code. The dealership is stumped as is TechLine who suggested the dealer replace the camshaft position sensor as a shot in the dark. It didn't fix the problem and I have given up on letting them try and because of that, it has become an occasional annoyance that I have just learned to live with. Here is some good news: It has NEVER done it under throttle and never at speeds greater than 15 MPH (24 KPH). After five or six incidents, I have noticed it comes around only after repeated short trips of slow-speed driving although I've yet to be able to actually cause it by doing so. There is an X-factor in there I just haven't been able to isolate yet. To be sure you are experiencing the same problem as I, there are a few criteria that I need you to confirm. 1. Were you applying any throttle at the time of the stall? Yes or no? 2. What was your speed at the time of the stall. I don't need a scientific measurement, just a guesstimate. 3. Did it do it so quietly and so subtly that you didn't notice until you needed a power-assisted function. Your reply is most appreciated because now that I know I'm not alone, I'm hoping we can team up against Hyundai and finally get this figured out once and for all.
- Andrew
'12 Elantra Limited w/Tech - 'Emma' Titanium Gray / Gray Leather ---- KDM headlights w/NightBreaker high beam bulbs, 30% tint all around, front plate delete with BumperPlugs, 37W fog lamp bulbs, Honda Fit wipers KYB rear shocks, 5K white license plate and trunk LEDs, V3 Triton rear turn signal LEDs, custom leather steering wheel wrap w/contrasted stitching, KDM aluminum pedal set. |
#4 (permalink) |
Andrew, have you performed the ground strap fix that SBR mentioned a while ago? If not, I wonder if the bad ground connection could be the cause of your stalling?
#5 (permalink) |
Former 2008 Hyundai Santa Fe, GLS, AWD, 2.7L owner.
2008 Honda Odyssey LX
This issue sounds like how "Idle air control" equipped vehicles would behave if they had IAC issues; Let off the gas and you *might* get a stall. Cold starts would have erratic idle as well.
Our Santys don't have an IAC motor/system because we've got electronic throttle control. It modulates itself- which leads me to think possible throttle position sensor issues? It's a tough find until something fails completely it sounds like. Joel |
#6 (permalink) |
Here has what they've tried so far, to no avail:
> Scan for codes, pending or otherwise. None found > Check fuel trims. No anomalies. > Clean ground straps > Replace camshaft position sensor per TechLine dartboard.
- Andrew
#7 (permalink) | |
Given the Santa Fe and its history of throttle-related issues, I think I'm going to give my dealer one final go at trying to nail this once and for all. Unfortunately it will have to wait until I get back from Texas on Sunday.
- Andrew
'12 Elantra Limited w/Tech - 'Emma' Titanium Gray / Gray Leather ---- KDM headlights w/NightBreaker high beam bulbs, 30% tint all around, front plate delete with BumperPlugs, 37W fog lamp bulbs, Honda Fit wipers KYB rear shocks, 5K white license plate and trunk LEDs, V3 Triton rear turn signal LEDs, custom leather steering wheel wrap w/contrasted stitching, KDM aluminum pedal set. Last edited by lovemysantafe; 10-27-2011 at 03:33 AM. |
#8 (permalink) | |
#9 (permalink) | |
I would say speed was 10-15. yes it did it stall quietly. I had no idea it stalled until i tried to turn at the bottom. I did not have the strength to turn it. Noticed all the lights were on as if I had just started it up. I took it to the dealer yesterday and they have no clue. No codes, not bad gas. Nothing. Sorry I can not provide more info. I had no clue it woudl stall so was more concerned watching out for children crossing the street directly below me. How did you get in touch with TechLine? Last edited by xtaski; 10-28-2011 at 08:23 AM. |
#10 (permalink) | |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| VE3XNP |
| Thread Tools | |
