Valve Adjustment In 07 Santy - Hyundai Forums : Hyundai Forum
Old 04-09-2010, 10:19 PM   #1 (permalink)
dabbdc
Send a message via Yahoo to dabbdc
I am coming up on the 60k and the manual says to adjust the valves. Picked up valve cover gaskets from the dealer today. Will I need a throttle body gasket? Anything else? The tappet clerances are in the owner's manual. How many hours does it usually take?
2007 Sante Fe Ltd (Sold)
53k miles (Bought at 50k as Certified)
K&N Drop In Air Filter
Deleted baffles in Air Intake
2009 Subaru Legacy GT Ltd
Stage 2 w open source tune
dabbdc is offline   Reply With Quote Quick reply to this message
Old 04-09-2010, 10:37 PM   #2 (permalink)
Perry Manessis's Avatar
Perry Manessis is an unknown quantity at this point
Adjusting the valves is the easy part, the time consuming part is moving the intake, valve covers, etc. Might as well change the plugs while you're at it.
Perry M
06 Sonata GLS I-4
07 Santa Fe Limited
Perry Manessis is offline   Reply With Quote Quick reply to this message
Old 04-09-2010, 10:57 PM   #3 (permalink)
dabbdc
Will do on the plugs. Does the intake plenum gasket get changed when you do this? Can't find an intake manifold gasket for the 3.3...
QUOTE (Perry Manessis @ Apr 9 2010, 10:37 PM)
Old 04-09-2010, 11:14 PM   #4 (permalink)
QUOTE (dabbdc @ Apr 9 2010, 09:57 PM)
I believe it's an O ring type gasket and from what others have said, they just reused it.
Perry M
06 Sonata GLS I-4
07 Santa Fe Limited
Old 04-10-2010, 07:39 AM   #5 (permalink)
Don67's Avatar
Pardon my ignorance, but is it really worth tearing down the top of an engine that is running quietly? The footnote in the manual does say "inspect for excessive tappet noise and/or engine vibration and adjust if necessary"
I used to check valve clearance religiously on my motorcycles, and the only times they ever needed adjustment was when they had become noisy. Even then, a little bit of slop was not considered harmful. The greatest risk was over-tightening the valves, followed by dropping crap into the engine or damaging a gasket during the job. Over time I learned to do the adjustment only when a clicking noise - more pronounced at all RPM than the idling fuel injector noise you hear on a Santa Fe - had developed.
Don67 is online now   Reply With Quote Quick reply to this message
Old 04-10-2010, 04:26 PM   #6 (permalink)
dabbdc
Having had many motorcycles - we fussed with such things every few hundred miles. No one but a BMW R60 owner went 60k miles on a bike in my day.
At 60k it does not strike me as overly fastidious to follow the owner's manual and adjust the valves, and as suggested above, throw in new plugs. I have purchased the VC gaskets so this issue has become moot at least for me
QUOTE (Don67 @ Apr 10 2010, 07:39 AM)
Old 04-10-2010, 04:27 PM   #7 (permalink)
dabbdc
At 60k it does not strike me as overly fastidious to follow the owner's manual an adjust the valves, abd as suggested, throw in new plugs. I have purchased the VC gaskets so it has become moot at least for me
Old 04-10-2010, 08:01 PM   #8 (permalink)
PoMansAWD's Avatar
PoMansAWD
Exactly and the 2007+ 2.7L and 3.3L V6 do not have a typical jamb-nut type lash adjusters. Read up on it. Hyundai calls them mechanical lash adjusters, but they are pretty much shim/bucket adjusters. It's a direct acting setup where the cams sit right on top of the valve stems (no rocker arms). In order to "adjust" them, you first have to measure between the cam lobes and MLAs with a feeler gauge, then tear down the entire top end, removing the camshafts, pull the MLA's and add the appropriate sized shims (washers). This is essentially a shim/bucket lash adjustment system. I surely wouldn't touch this on a ~3yr/old vehicle with under 100Kmi. Definitely not on the chain driven cam(s) 3.3L. The chain has to come off along with everything else.
Joel
PoMansAWD is offline   Reply With Quote Quick reply to this message
Old 04-10-2010, 11:33 PM   #9 (permalink)
dabbdc
Thanks Joel, I guess I will leave the top end alone
Old 04-11-2010, 08:18 PM   #10 (permalink)
PoMansAWD's Avatar
PoMansAWD
QUOTE (dabbdc @ Apr 10 2010, 11:33 PM)
You could still pull the cam covers and check all 24 with a feeler gauge if you suspected an issue. Then again, in order to remove the rear cam cover you'd have to pull the intake manifold to gain access to the sparkplugs, etc. Lots of work. I guess in the end, these shim/bucket systems are designed to last the life of the vehicle. You'd be better off installing a whole new set of loaded heads on the engine than mess with them!
Joel
