Headlights Dimming - Hyundai Forums : Hyundai Forum
Old 03-23-2010, 01:17 AM   #1 (permalink)
cyper2002
Hello, I noticed for a while now that sometimes when I use the brakes in my 2007 santa fe the headlights dim momentarily. It may just happen shortly after taking the car out, as thats when i usually notice it. Anyone have any guesses as to what could cause this? Could it be an alternator problem?
cyper2002 is offline   Reply With Quote Quick reply to this message
Old 03-23-2010, 02:34 PM   #2 (permalink)
PoMansAWD's Avatar
PoMansAWD
What you describe is pretty common when several high electrical loads kick in at once. I know on my 2008, I can get a quick dim when the ABS module runs it's self test the first time you hit ~20mph after startup, which the heater blasting, rear defroster on, etc..
Joel
PoMansAWD is offline   Reply With Quote Quick reply to this message
Old 03-23-2010, 03:28 PM   #3 (permalink)
cyper2002
thanks for the reply. Yeah it happens really quickly like you describe, its probably just normal then. I have generally had the heat and defrosters running when i notice it too.
Old 03-25-2010, 09:38 AM   #4 (permalink)
fuzzai
If you don't like your lights dimming, upgrade your alternator to a higher power one, just too much load on the system at once.
I remember when i was younger with a stereo system, headlights would dim when the music was loud Same idea, bigger battery, bigger alternator.
Not really an issue in a stock vehicle thoe
fuzzai is offline   Reply With Quote Quick reply to this message
Old 03-25-2010, 10:29 AM   #5 (permalink)
PoMansAWD's Avatar
PoMansAWD
Yep, a higher capacity battery and cabling with lots-o-copper can help with this issue too.
Joel
Old 03-25-2010, 04:33 PM   #6 (permalink)
cyper2002
QUOTE (fuzzai @ Mar 25 2010, 09:38 AM)
QUOTE (PoMansAWD @ Mar 25 2010, 10:29 AM)
Joel
Thanks guys! I don't need to spend the money upgrading anything though, it isn't really an issue for me as long as it's normal. I was just making sure it wasn't abnormal or a sign of something going bad, ready to break, etc. Thanks for the help though!
