lack of power,misfire,rough idle and stalling - Hyundai Forums : Hyundai Forum
Old 11-03-2009, 07:58 AM   #1 (permalink)
sheraz80
I am new in this forum. I just bought new xg30 1999 with 62000 KM. I am having following problems,
When I turn AC on in Neutral or Parking, RPM are fine but as I shift Drive or Reverse then engine starts shaking and RPM dance between 400 to 900 and it seems like engine will turn off. But if I again shift to Neutral or Parking it will come again to normal.
Miss fire happens most of the time when I drive from stop and even at higher speed. It seems like I can not even get high RPM properly putting paddle downwards and also engine has lack of power. But some times it is just normal and drive smoothly. (AC problem exists)
Misfire also happens above 3000 rpm. Its kind of like cutting fuel supply to engine.
Check Engine Light is not on.
I will appreciate help.
sheraz80 is offline   Reply With Quote Quick reply to this message
Old 11-03-2009, 02:16 PM   #2 (permalink)
sheraz80
Hi there
Can anybody help me out regarding the problem I have written above. Please suggest according to your experience what shall I do and what should be inspect accordingly.
Well I have found out the pressure leakage at 1st and 3rd fuel injectors. O-Rings were damage. Change them but still rough idle. Small Vacuum pipe going out of front injector line to the relay attached after to it always clicks randomly as I give accelerator. Do not know if it is normal or some defect.
Old 11-04-2009, 12:17 PM   #3 (permalink)
sheraz80
Update from today!!
First of all I feel nobody here is to help as I did not get any reply or seggestions. Moderator and Admisitrator could suggest something to check according to their experience.
Well today I took MAF connector off and I saw rpm is very smooth and it even goes to 7000 very smoothly and this relay (connected to the vacuum pipe coming out of fuel injectors) does not clicks randomly. No misfire at all. As I put MAF connector again on problem came back. Engine stall, misfire happened and rpm does not go up smoothly and if it does engine stall in between and this relay again click randomly.
I do not have check engine light on even when I took the MAF connector off. I never saw it on even if I turn ignition on. I do not know if it is out of order or it never turn on until you have problem.
Could any one please suggest me if it is MAF sensor not working properly or what could be a problem.
Tomorrow have a pollution test. Do I have to take it before this problem is fixed or first fix it and take a test.
I would highly appreciate help of you guys and thanks to you all in advance.
Old 11-04-2009, 12:47 PM   #4 (permalink)
ADMINISTRATOR
Montego's Avatar
firstly you must remember that you will not always get an instant reply to your posts. it would depend on when members that have the knowledge to answer your questions are on-line. sometimes you maybe lucky but other times you may have to wait several days. also bear in mind that members may not be able to answer your question.
however to your other point. it does from what you say sound like you are having trouble with the MAF. if this becomes faulty it does not normally trigger the CEL (as in your case)
if you are going to take your car for an inspection l would keep the MAF plugged in for now but it does look like you will need a new one
l hope this answers your question
MONTEGO
Old 11-04-2009, 01:30 PM   #5 (permalink)
sheraz80
Thank you very much for your answer.
But is it normal if you turn your ignition on check engine light does not come on. Because in my case i never see it on.
What is this relay which act strange and start click randomly upon connecting the MAP connector. It does also when I turn on A/C .
I just want to make sure that this is problem with MAF sensor and do not want to spend money around as the previous owner has to changing the ECU, Alternator, Battery etc.
Could you please suggest something esle to check to make sure this problem is with MAF sensor?
Well I would say thanks to all of you making and arranging this forum. It saved us lot of money and headache upon your experience with this very complicated electronics structure of xg's.
Old 11-04-2009, 03:10 PM   #6 (permalink)
ADMINISTRATOR
Montego's Avatar
your CEL should come on when you turn on the ignition. you have a problem there (it might just be the bulb broken)
under the circumstances l would strongly suggest you have any possible fault codes read with a scanner. (if your CEL is not working you have no way of knowing if you have any faults)
you suprise me when you say that the last owner had to have the ECU changed. l have never heard of anyone having to change the ECU on a XG (alternator and battery are common)
BTW the clicking that you can hear is normal.
again, best get the codes read before you spend anymore money
MONTEGO
Old 11-04-2009, 03:36 PM   #7 (permalink)
sheraz80
Well I have got the bills from last owner and the garage who has checked with GDS got following code P0743
I do not know what this code is actually for.
I can read the following, TCM Defect must change ( This all bill and diagnose written in German)
and something written they checked lot of wires as there were not proper communication between torque converter clutch and TCM
Motor-Steuergerät (ECU) changed ( Part No. 39110 39168).
I am surprised too and I do not think if it was the right problem to change the ECU. What you suggest what is this code P0743 for?
If they just did it and code does not refer to this I would talk to them as I got it all in written and they charged like 2600.- swiss franks.
About this clicks from relay, is it some kind of vacuum adjuster from the fuel injectors?
Old 11-04-2009, 06:03 PM   #8 (permalink)
ADMINISTRATOR
Montego's Avatar
code PO 743 is torque converter clutch circuit (electrical malfunction)
l can't give you a positive answer about the 'clicking' ATA SOLENOID DIAGNOSTIC TROUBLE CODES P0740, P0743, P0750, P0755, P0760, P0765, P0770
This TSB supersedes TSB# 01-40-010 to correct repair information.
DESCRIPTION:
Incorrect operation of the transaxle solenoids may result in the following symptoms:
  • <LI class=ITEM>Erratic shift<LI class=ITEM>Transaxle held in 3rd gear Fail-Safe<LI class=ITEM>Diagnostic Trouble Codes P0740, P0743, P0750, P0755, P0760, P0765, P0770
  • MIL illuminated
NOTEDo NOT replace the transaxle for solenoid codes listed above. Instead, follow the repair procedure shown below.
REPAIR PROCEDURE:
  • Using a Hi-Scan Pro, check for DTC in both the "Engine" and "Automatic Transaxle" menus. Record the DTC and description
  • Disconnect the connectors between the solenoid and TCM. Check for bent pins or pins not fully inserted in the connector. Repair as necessary. NOTEClean connector pins with a contact cleaner listed below, or equivalent:
    • NAPA Electronic Cleaner, P/N 765-1843
    • MOPAR MP-50 Electrical Contact Cleaner, P/N 04549626
    • Permatex Electrical Contact Cleaner, P/N 24379 or equivalent.
  • Check the wiring harness between the TCM and transaxle for a damaged wire or a short circuit to ground. If so, repair or replace the ECM control harness, P/N 914XX-XXXXX.
  • Check the harness inside the transaxle oil pan for a short circuit to ground. Replace the harness if damage is found or if three or more solenoid DTC are found in Step 1. (Refer to TSB# 02-40-009 for instructions). MODELHARNESS P/NSonata, Elantra, Santa Fe, Tiburon
    46307-39050
    XG300/350
    46308-39550
    Oil temperature sensor
    46386-39050
    Valve body gasket
    46264-39510
  • <LI type=1 value=1>Refer to the DTC recorded in Step 1 and follow the repair procedure shown below: DTCREPAIR PROCEDUREP0743, P0750, P0755, P0760, P0765, P0770, or P0740 together with P0743
    Replace the related solenoids
    P0740 only (no other solenoid DTC found)
    Check "Engine" and "Transaxle" menu for DTC:
    • If no DTC P0335 or P0725, replace the transaxle.
    • If DTC P0335 or P0725, follow procedure below.
    P0335 (Crankshaft position sensor malfunction)
    Check harness and connectors to CKP sensor and ECM/TCM. If OK, replace CKP sensor. Delete solenoid DTC.
    P0725 (CKP sensor - open circuit)
    P1529-TCM MIL request signal
    Delete code
REPLACING THE SOLENOIDS:
  • Remove the battery.
  • Drain the radiator. Remove the lower radiator hose from the radiator.
  • Drain the ATF.
  • Remove the valve body cover from the transaxle.
  • Refer to the DTC recorded in Step 1 and replace the related solenoid according to the diagram shown. Tighten the bolts to 4-5 lb.ft (50-70 kg.cm). Go to step 11.
  • Apply Ultra Gray Gasket Sealer, P/N 00231-13800 to the valve body cover and reinstall the cover. Tighten the bolts to 6-7 lb.ft (80-100 kg.cm).
  • Add approximately five quarts of SPIII ATF and check the level with the engine idling in Neutral. Recheck the ATF level when the ATF is at normal operating temperature (70-100°C, 159-212°F).
  • Clear the codes and test drive the vehicle for two driving cycles (two key-on to key-off driving cycles, including 1-2-3-4 upshifts and 4-3-2-1 downshifts). If the DTC returns, perform the following repairs: DTCREPAIRP0743, P0750, P0755, P0760, P0765, P0770, or P0740 together with P0743
    Replace the TCM. If DTC returns, replace the ECM control harness, P/N 914XX-XXXXX.
PARTS INFORMATION:MODELPART NUMBERPART NAME1999-2003 Sonata
46313-39050
Solenoid Valve (Qty 1)
2001-03 Santa Fe
2001-03 XG300/350
2001-03 Elantra
2003 Tiburon
ALL
00230-11000
SPIII ATF
WARRANTY INFORMATION:MODELOPERATIONOP CODEOP TIMEOP QTYNATURE CODECAUSE CODE1999-2003 Sonata
Replace Solenoid
45775R00
2.6 M/H
*N27
**C31
2001-03 Santa Fe
2001-03 XG300/350
2003 Tiburon
2001-03 Elantra
Replace Solenoid
45775R0B
All
Scan Tool Operation
45775RP0
0.3 M/H
Normal warranty applies.DTC INFORMATION:
For your reference, the logic the TCM uses to set solenoid codes are listed below:NOTEDo NOT replace the transaxle for those codes listed as "Open/short". Refer to the tables for additional information.
TCM DTC - 1999-03 Sonata, 2001-03 Elantra, XG And Santa Fe, 2003 Tiburon:
COMPONENTTCM DTCMALFUNCTION CRITERIATIME REQUIREDDRIVING CYCLESMILCOMMENTDCCSV
P0743
Open/short
0.3 sec.
Yes
Electrical condition
L And R
P0750
UD
P0755
2ND
P0760
OD
P0765
RED
P0770
DCCSV
P0740
Solenoid duty 100%
4 sec.
Hydraulic or damper clutch condition
MONTEGO
Old 11-04-2009, 06:09 PM   #9 (permalink)
pat19581
about your check light when i got my car someone had cut the wire at the back of the clocks so the light didnt come on soon as i conected it back up check light was on all the time think they had cut it so i didnt no it had a fault when i got the car
pat19581 is offline   Reply With Quote Quick reply to this message
Old 11-06-2009, 02:51 PM   #10 (permalink)
sheraz80
Dear montego
Thanks for your kind and detailed reply. TCM has been replaced or repaired from last owner with the code PO 743 shown on the bill.
As I can feel my CEL has been disconnected or bulb is not working fine first I have to make it working and see if CEL is on. If yes I would bring it to have the all codes read.
My only problem at the moment,
[b]MAF connector attached (lake of power in Engine, misfire, engine stalls, etc) and automatic confused sometimes between 3 to 4 and 4 to 5.
MAF connector disattached, (no misfire, rpm goes up till 7000 without any problem)
I am still not sure if this is the problem is with MAF or something esle could be. How I can be make sure with the MAF before to replace it as it costs 500 CHF. Is there any other mathoed to check it?
Well I had yesterday my anti polution test and it was all fine.
I will soon update with codes if there are any in ECU.¨
Inbetween any solution or check with MAF?
