Timing Belt Quote - Page 2 - Hyundai Forums : Hyundai Forum
Old 07-17-2013, 08:32 PM   #11 (permalink)
2004 accent
zero_gravity is an unknown quantity at this point
Originally Posted by thedurk View Post
I figured to do just the belt and idlers at 60k and leave the WP for 120k. By 75k, I had to go back in and do the WP. Lesson learned.
are you talking in miles?? the timing belt does not need to be done that early nor should the water pump fail that early...
zero_gravity is offline   Reply With Quote Quick reply to this message
Old 07-18-2013, 11:13 PM   #12 (permalink)
2008 Accent GS 5-speed.
thedurk
Yes, miles. Hyundai says it does need to be done at 60k in their maintenance schedule that came with the car.. Plug in 60000 miles and '08 Accent into this site:
https://xws.xtime.com/xmmmenu/?varia...&inframe=false
and you get: "Replace Timing Belt" next to last on the list. Given the warranty and interference engine, I was not going to go longer. As to the WP, I agree it shouldn't fail that early, but it was dripping from the pulley shaft and going through a quart of coolant a month. Now it's tight again.
thedurk is offline   Reply With Quote Quick reply to this message
Old 07-19-2013, 02:24 PM   #13 (permalink)
2009 Hyundai Accent GS Base 2008 Kia Rondo - V6 w third row seating
JoeSixPack is an unknown quantity at this point
Having just picked up a 2009 Accent I can also confirm that the manual calls for a timing belt change ever 60k miles.
That seemed a little low to me but I'm not going to F with it and push it.
In my case with only 27,000 miles on a 4 year old car I've gotten the sense that I should do the timing belt at the 5 year mark (technically they say 60k miles or 60 months).
From what I've gleaned from others, the water pump should NOT need to be replaced that soon (though I'd do the pulleys with the belt)
In past vehicles (2000 Jetta TDI) I'd change both the pump and belt since the pumps were pretty cheap and it made sense to save on the labor (and they recommended it only every 80k miles) - but in this case with a water pump that will likely only have about 40,000 miles on it, I'm thinking I'm OK keeping the existing water pump - probably/hopefully until the next timing belt change at 100k miles.
JoeSixPack is offline   Reply With Quote Quick reply to this message
Old 07-19-2013, 06:57 PM   #14 (permalink)
omg grip's Avatar
2009 Accent SE
omg grip is an unknown quantity at this point
your waterpump should be fine. ive read only one instance of someone who didnt change it at 60k and it started leaking around 90k. I am at 95k now and mines fine. if mine ends up leaking before 120k, whatever, i learned how to change the timing belt last time, its a fairly easy job once you learn your way around the car.
omg grip is offline   Reply With Quote Quick reply to this message
Old 07-22-2013, 07:59 AM   #15 (permalink)
johnirvine1's Avatar
07 Accent HB 03 CBR600RR
johnirvine1
I had my timing belt, water pump done for $650. My car is now at 118,100 mi
http://www.cardomain.com/ride/3340962
My Youtube page (Over 17 million views)'
My website/business 'IRVINE BROTHERS PHOTOGRAPHY'
07 Accent SE w/122,xxx mi ,16s, AEM SRI, DC Sports front strut bar, Megan lowering springs (not installed yet)
johnirvine1 is offline   Reply With Quote Quick reply to this message
Old 09-16-2013, 04:22 PM   #16 (permalink)
Lost100110's Avatar
Accent 08, Custom SRI, 8000K HIDs Retro fit, Mega Raizin Ground, Touren Wheels, Isotta Pedals &
Lost100110 is an unknown quantity at this point
So just had the work done today happy to say the dent in my wallet was only minimal, a break down in prices was a followed:
279$ for timing belt change
80$ for all three other belts
And some brake work 40$
A grand total of 450$ with tax!
Lost100110 is offline   Reply With Quote Quick reply to this message
Old 09-16-2013, 07:38 PM   #17 (permalink)
2004 accent
ok my bad. that just seemed very early, but if thats what the OM calls for i would get it done. i drive a LC accent, the change interval must be a bit longer. i also treat it like the piece of crap it is....i did the belt at 160k kms which is longer than the maintenance schedule by a bit, but i did regular checks on it to make sure the belt wasn't eating itself yet.
$450 for that job is quite good! sounds like you did alright!
