Multiple coil problems with 2011 Accent - Hyundai Forums : Hyundai Forum
Old 06-05-2013, 12:32 AM   #1 (permalink)
2011 hyundai accent
journalista is an unknown quantity at this point
Default Multiple coil problems with 2011 Accent
My 2011 Hyundai, at 34,000 mi., has had all 4 coils "go bad" one after the other over the past 12,000 miles. All coils were replaced under warranty at the Long Beach CA dealership. Now the first replaced coil has failed and the dealership says the only fix is to keep replacing them. Does anyone know if there is an underlying problem?
journalista is offline   Reply With Quote Quick reply to this message
Old 06-05-2013, 12:55 AM   #2 (permalink)
Drives 2011 Hyundai Accent GS 3-Door Dark Sapphire Blue
Gir92
I just had a coil go bad at 23.4k miles as well.
Gir92 is offline   Reply With Quote Quick reply to this message
Old 06-07-2013, 11:44 AM   #3 (permalink)
And Don't Call Me Shirley is on a distinguished road
I've heard of coil problems in these cars from time to time, have yet to see it firsthand. 95k+ on ours without a coil problem.
Curious how this plays out...
And Don't Call Me Shirley is offline   Reply With Quote Quick reply to this message
Old 09-20-2013, 09:14 AM   #4 (permalink)
Drives 2011 Accent
dougweinhold is an unknown quantity at this point
I've had the same problem - the coils went twice, and I'm taking it into the dealer tonight for what is probably the third time. First and second were at ~40k and 50k miles, now it has 61.5k. They blamed it on the plugs, but had new ones put in at 50k too. Did you find out what caused your problems?
dougweinhold is offline   Reply With Quote Quick reply to this message
Old 09-20-2013, 12:59 PM   #5 (permalink)
omg grip's Avatar
2009 Accent SE
omg grip is an unknown quantity at this point
i would think something "upstream" of the coils is causing them to fail prematurely.
i just hit 100k miles yesterday, not a coil problem yet.
omg grip is offline   Reply With Quote Quick reply to this message
Old 09-21-2013, 09:53 PM   #6 (permalink)
2004 accent
zero_gravity is an unknown quantity at this point
has anyone bothered to check the voltage incoming to the coils?
zero_gravity is offline   Reply With Quote Quick reply to this message
Old 09-23-2013, 05:20 PM   #7 (permalink)
Drives 2011 Hyundai Accent Gl
fnv12 is an unknown quantity at this point
I wonder how they break. Do they "burn out" like light bulbs all of a sudden or is it more progressive, and then past a certain point their activity isn't strong enough to do anything? If it is progressive maybe they can be periodically checked how hmaservice says to check them.
fnv12 is offline   Reply With Quote Quick reply to this message
Old 09-23-2013, 05:44 PM   #8 (permalink)
2004 accent
the coils are really just a transformer - converts current into voltage. you get low voltage and 'high' (ha) current coming in and then very low current and very high voltage coming out. the net energy has not changed minus a small amount lost due to the efficiency. its actually very very small.
so to answer the question of is it fast or not, it really depends on the failure. if insulation on the windings is breaking down, i'd imagine it would happen bit by bit until it his that complete failure point.
if you're getting moisture in there...well i think everyone can figure that one out.
Old 09-24-2013, 10:06 AM   #9 (permalink)
blueblaze's Avatar
2010 Black Hyundai Accent Sedan 4DR
blueblaze
my car run up to today 147K kilo and thanks that no problem in the coil...
but my friend called me up today, he said that his car had some misfires symptoms, i said to him to change the fuel filter(cause i change mine already when i have the same problem) but again he still have the same symptoms, let us try to change the coil or the SP wire...
INSTALLED
205/50/16 ET52 GT; Sony Xplod System; EZ-LIP Front & Aero Side Skirt; NGK IFR5E11; Magnaflow 11255 w/35130; K&N 57i (57-0520) w/shield; Bosch Horn; Front LED Lights; Red Brembo Brake Cover; 3pc Gauge (oil temp/press/water temp); Oil Catch Can; Eibach Pro-Kit, Technica Front Strut Bar
blueblaze is offline   Reply With Quote Quick reply to this message
Old 09-25-2013, 03:27 PM   #10 (permalink)
2004 accent
or you could diagnose the problem instead of throwing random parts at it. that would be too hard though wouldn't it?
