LinkBack | Thread Tools |
#11 (permalink) | |
2013 Gen Coupe 2.0T R-Spec
Duro |
| Sponsored Links | |||
Advertisement | |||
#12 (permalink) |
Three 2004 Santa Fe's 2.4L
2009 Accent 1.6L
So when it comes to replacing the shocks on a 2009 Accent, is it as easy as it is for a Santa Fe? I found this YouTube video for the Santa Fe
and it makes this job look simple enough for even ME to do it!
Is there anything much different for the 2009 Hyundai Accent in this regard?? |
#13 (permalink) | |
Drives 2008 Accent MC Auto Sedan
#14 (permalink) |
MODERATOR
Drives: 2013 Chevrolet Sonic LT 1.4 turbo/6AT, Accent MC (gone but not forgotten.)
Yeah I can do that, I will gladly display my stupidity.
![]() It might be a while but I will get a pic next time it's off the ground. I just changed oil in it about 500 miles ago. I'm not liking how the slush box is shifting so I may get it back up on ramps soon to change the fluid. I guess I shouldn't say bent, it's probably more like a dent. I may have had the jack in the wrong place, who knows. Others here haven't had that happen to their MC when lifting with the cradle. BTW, got the KYB's in, they look really nice. I will probably wait until it warms up before tackling the replacement. Sent from AutoGuide.com App
Ride Of The Month Last edited by hoosieraccent; 01-30-2013 at 01:43 PM. |
#15 (permalink) |
Drives 2010 I30 Man. Diesel
Hers 2007 Accent Auto.
Work Kia Pregio Van Diesel
I have just changed the rear shocks on a 2007 Accent, you don't even need to remove the road wheel. Just jack the body up high enough to access the top mount bolts visible over the top of the tyre, the tyre doesn't even leave the ground. Then after putting a block of wood or safety stand under the body as well, slide under the back and take out the lower mount bolt, this one was tight and I had to use an extension on my ring spanner to loosen it. After that the unit just falls out, it really was a 20 minute job and the ride improvement was incredible.
#16 (permalink) |
MODERATOR
Thanks for the input, that sounds great!
What's involved with switching the top mount over from old to new? Sent from AutoGuide.com App
Ride Of The Month |
#17 (permalink) | |
Duro |
#18 (permalink) |
2009 Accent 1.6L
I took a look at the rear shocks on my 20009 Accent today as well... So I just want to confirm that the two bolts at the top of the shock, accessed from under the car will realease the top part of the shock? And then just the big single bolt at the bottom?
In the video I posted in this thread earlier, which is a shock replacement for a Santa Fe, the top connector is accessed from a panel inside the back hatch of the vehicle. Not so for the Accent?? |
#19 (permalink) |
MODERATOR
Those two top bolts and one bottom are all it is. You don't have to access anything from inside the car.
Ride Of The Month |
#20 (permalink) | |
Duro |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
