Bought used 2010 Accent... - Hyundai Forums : Hyundai Forum
Old 11-21-2012, 03:11 PM   #1 (permalink)
Drives Accent MC 2010
micallen is an unknown quantity at this point
Default Bought used 2010 Accent...
Shortly after leaving the lot, the low air pressure light came on, and the check engine light.
The tires themselves state Max Pressure 44lbs. I checked, and each had around 28 lbs. So I inflated up to 44 lbs (all tires). The light is still on.
Do I likely have a bad sensor? Can a tire sales place check that for me or do I need to take it to Hyundai?
Thanks,
Micallen
micallen is offline   Reply With Quote
Old 11-21-2012, 05:02 PM   #2 (permalink)
The_AirHawk's Avatar
12 Veloster 08 Accent GLS(R.I.P.) 08 Bullitt Mustang 04 Yamaha FZ6 82 Dodge D150 83 Iveco Z110
The_AirHawk is an unknown quantity at this point
Drive it awhile. The light will go off in a mile or two.
You might want to decrease that pressure - just 4-6psi; for a more-supple ride.
Parfois, on fait pas semblant!
The_AirHawk is offline   Reply With Quote
Old 11-21-2012, 06:40 PM   #3 (permalink)
Voivod's Avatar
2007 Hyundai Accent GS in Wine Red.
Voivod is an unknown quantity at this point
That's the maxium pressure they can handle, cold. The factory recommended PSI for the stock tire size can be found on the plate on the pillar when opening the driver's side door. I beleive it's 30-32 depending on tire. At least that's what's in my '07's owner's manual.
100% Suburban Driving.
Visit my photography thread!
Voivod is offline   Reply With Quote
Old 11-21-2012, 09:42 PM   #4 (permalink)
OK. Pressure decreased. Driven another 10 miles or so, and the light is still on.
Old 11-22-2012, 05:21 AM   #5 (permalink)
Interesting. Typically, the light goes out within a mile or two (or a couple of key-on cycles).
Could be a bad sensor, or a bad battery on one (or more) sensor(s) (it happens, but not often). Could be the TPMS transceiver is malfunctioning.
Determining WHICH one is the culprit - that's going to be the "fun" part.
You may be time/frustration/money ahead taking it to a Dealer.
Old 11-24-2012, 08:09 PM   #6 (permalink)
2010 Accent GLS, rare 5 speed
austex04 is an unknown quantity at this point
Does it have warranty? Take it back to the dealer, they need to fix it. Bumper to bumper warranty is 5 years/60k miles. Tire inflation is 32lbs per Hyundai, I run 34lbs becouse I sometimes drive at high speeds for long distances, we have fast speed limits here.
austex04 is offline   Reply With Quote
Old 11-24-2012, 10:24 PM   #7 (permalink)
2013 Gen Coupe 2.0T R-Spec
Duro5341 is an unknown quantity at this point
Agreed.....
I run 35 PSI (cold) in the front, and 32 PSI (cold) in the rear, and I don't have the OEM tire feathering issue, and I am a very spirited driver to boot. I run more in the front as the front is carrying more weight than the rear.
Duro
Duro5341 is offline   Reply With Quote
