Help on my car please - Hyundai Forums : Hyundai Forum
Old 06-17-2012, 10:39 AM   #1 (permalink)
Hyundai Accent 07
marc07 is an unknown quantity at this point
Default Help on my car please
My Hyundai accent 2007(manual) has a good traveling and acceleration but when problem started when at the stop light, as soon as the green light. i start moderateling from Gear 1, it makes weird noises like it is choking, then time to time, from stop to Gear 1,the engine will stop like no fuel went in the engine. and then, when I start the engine, the starter just revolves and the engine wont run.
I tried so many things then came up with opening the hood, removing the battery ground terminal, and returning it again. then it will start normally again. and also, my RPM gets high on neutral. Please help me. what is wrong?
solutions made(but problem repeats):
1. changed fuel filter, changed oil and oil filter
2. cleaned fuel injector which are also electrically okay.
3. cleaned carb
4. changed air filter
5. changed relays
6. used carb cleaner with fuel.
marc07 is offline   Reply With Quote
Old 06-17-2012, 04:19 PM   #2 (permalink)
bloodninja's Avatar
2008 Hyundai Accent SE (auto)
bloodninja is an unknown quantity at this point
You cleaned the carburetor? That's awkward
bloodninja is offline   Reply With Quote
Old 06-17-2012, 04:32 PM   #3 (permalink)
TreyDog650's Avatar
07 Accent GS
TreyDog650 is an unknown quantity at this point
Lol
TreyDog650 is offline   Reply With Quote
Old 06-17-2012, 11:47 PM   #4 (permalink)
Drives 2007 Hyundai Accent
sandman81
Originally Posted by TreyDog650 View Post
Lol
x2. Please explain how you cleaned the carb.
sandman81 is offline   Reply With Quote
Old 06-18-2012, 01:38 AM   #5 (permalink)
Hyundai Accent 07
I just sprayed WD40 and cleaned outside of it.
Guys, please dont make fun of me. I just need some help here
Old 06-18-2012, 06:14 AM   #6 (permalink)
pare_john's Avatar
Your car does not have a Carb. most likely what you are referring to in the TB (Throttle Body)
How exactly did you clean the TB? Did you spray WD-40???????
pare_john is online now   Reply With Quote
