Timing Belt Replacement? - Hyundai Forums : Hyundai Forum
Old 05-22-2010, 12:26 PM   #1 (permalink)
shdowflare
So I see the timing belt is to be replaced every 60k... what are the downsides to holding off on this? I asked my mechanic and he said to just run it until it wears out and needs to be replaced. What do you guys think? Is this good advice? Apart from a voided warranty, what else is at risk?
THanks!
shdowflare is offline   Reply With Quote Quick reply to this message
Old 05-22-2010, 12:32 PM   #2 (permalink)
bloodninja's Avatar
2008 Hyundai Accent SE (auto) (sold)
bloodninja is an unknown quantity at this point
Downside.. your powertrain warranty WILL be void if you do not replace the timing belt @ 60k. That's not a dealer thing, that's Hyundai Corp. That's a pretty awful idea to wait until it wears out.
Would you do that for your brakes? Wait until you can't stop anymore, and then replace them?
bloodninja is offline   Reply With Quote Quick reply to this message
Old 05-22-2010, 12:41 PM   #3 (permalink)
pjoduo's Avatar
pjoduo
A while back I remember someone on here that did not replace it, it went at around 70k I believe and all his valves were smashed because of it.
I would not recommend waiting.
pjoduo is offline   Reply With Quote Quick reply to this message
Old 05-22-2010, 12:58 PM   #4 (permalink)
ADMINISTRATOR
Montego's Avatar
QUOTE (shdowflare @ May 22 2010, 05:26 PM)
THanks!
its like plying russian roulette with your engine......................do you feel lucky?
MONTEGO
Old 05-22-2010, 01:56 PM   #5 (permalink)
Burnitwithfire's Avatar
2010 Accent LE 5spd
Burnitwithfire is an unknown quantity at this point
QUOTE (shdowflare @ May 22 2010, 12:26 PM)
THanks!
Get a new mechanic, seriously. It's a timing belt not a power steering or alternator belt we're talking about. If it breaks, you'll be looking at new valves, lifters, guides, maybe a camshaft or two, pistons and possibly cylinder bore damage if a valve breaks off its stem.
This is what will happen if you "wait until it wears out"
Happened on my 1991 Passat Syncro. I got EXTREMELY lucky because the belt stripped right when #2 exhaust and #3 intake (IIRC) valves were overlapping and I was idling. It didn't damage anything except my pride for not replacing it when I didn't know its mileage. This is a one in a million chance, most 20v 1.8t engine will bend valves.
DO NOT WAIT!!!
I hate signatures with pictures.
Burnitwithfire is offline   Reply With Quote Quick reply to this message
Old 05-22-2010, 02:52 PM   #6 (permalink)
ultragod's Avatar
Drives: 2007 Hyundai Accent GS Rides in: 2008 Hyundai Santa Fe G
ultragod is an unknown quantity at this point
Send a message via AIM to ultragod Send a message via MSN to ultragod Send a message via Yahoo to ultragod
I also got lucky when my timing belt broke. Like everyone says, do not wait. If your mechanic said to wait, either he has never worked on a car before, or he wants your money, and all of it. You really don't want to wait, like burnit said, you WILL be replacing a lot of internals if you do.
Your lack of punctuation in your post hurt my brain and I honestly can't tell what it is you are trying to say, so I will assume you are agreeing with me. In that case, thanks!
Enter YOUR car in this month's ROTM and be the envy of your friends, enemies, frenemies, and even total strangers if you win!
ultragod is offline   Reply With Quote Quick reply to this message
Old 05-22-2010, 02:56 PM   #7 (permalink)
2008 Sonata 3.3 LTD 2010 Dodge Ram 1500 Hemi 1995 Ford Taurus GL 2009 Sonata 2.4 GLS
ken99 is an unknown quantity at this point
QUOTE (shdowflare @ May 22 2010, 10:26 AM)
THanks!
The possability of a total engine replacement is the downside to this strategy. I think your mechanic is a m*r*n for giving you such advice. Timing belts break when they wear out. This link shows the consequences of a broken timing belt on Kia Rio, which is more-or-less a Hyundai Accent clone:
http://www.kia-forums.com/236438-post5.html
I would replace the belt now if it is due.
ken99 is offline   Reply With Quote Quick reply to this message
Old 05-23-2010, 11:05 AM   #8 (permalink)
jptrsn
Another vote for doing it according to spec. It's just not worth the risk!
Even if it doesn't snap completely, you might lose a tooth or skip one, leading to rough idling, detonation, or pre-ignition. Ever had two stereos playing the same thing slightly out-of-sync? If you think that sounds bad, wait'll you hear an engine with skipped timing!
Just get it done. And probably not at that mechanic...
jptrsn is offline   Reply With Quote Quick reply to this message
Old 05-23-2010, 11:32 PM   #9 (permalink)
ausom accent 9's Avatar
2009 Accent SE
ausom accent 9 is an unknown quantity at this point
Hyundai Auto Canada recommends every 60 mths regardless of milage My last car the tensioner seized...smoking
the belt...but it was a none interference engine Why dont they just put chains on these things????
ausom accent 9 is offline   Reply With Quote Quick reply to this message
Old 05-24-2010, 10:28 PM   #10 (permalink)
MODERATOR
Drives: Accent MC (gone but not forgotten.)
QUOTE (ausom accent 9 @ May 23 2010, 11:32 PM)
Fortunately they finally are beginning to... As Hyundai phases out their old engines the belts are going as well. *AFAIK, in the North American market at least, only the Alpha and Beta are left with a belt.
Ride Of The Month
Forum Rules
hoosieraccent is online now   Reply With Quote Quick reply to this message
