Accent Lc 1.6 Turbo Probleme On Boost - Hyundai Forums : Hyundai Forum
Old 08-05-2008, 08:40 AM   #1 (permalink)
alexlab79
hello, first my english is a litle bad, i am french canadien.
I turboed my accent 2006(lc2)
My stock list:
1.6L
turbo kkk03 set at 7psi
bov
intercooler
home made simple AFC(when boost occur computer see O2 sensor very lean an enrich mixture at aprox 12-13:1..it's work good)
home made return line
FMU 6:1 and FPR
i have probleme when boosting but not allways, the car hesitate or not give me the full power...is very strange...first, when a snap the trottle in the floor, i feel the power but after one or 2 second, the car buck 1 or 2 second and i don't feel the power after but boost is at 7psi, if i release the trottle for less boost 2-4 psi at max..i feel the power...
my problem occur whitout my home made cheap AFC(But the buckage is less strong with my cheap AFC) ... i think is probably my map read too much pressure and cut the fuel but i have read in this forum the stock ECU and Stock map do not cut fuel above 14.5psi of boost?!?!
Assumption :
1-Map cut fuel
2-I don'T have tried to run a colder sparkplug, i run my stock sparkplug...?!
3-Timming/compression to advanced/high
all helps is apreciated thanks...and very sorry for my limited english!
alexlab79 is offline   Reply With Quote Quick reply to this message
Old 08-08-2008, 07:12 PM   #2 (permalink)
gbajosh
The accent engine is not ready for a 7 psi boost.
Why don't you drop the boost, or remove the whole turbo and put in a car that can handle it?
gbajosh is offline   Reply With Quote Quick reply to this message
Old 08-09-2008, 03:16 AM   #3 (permalink)
bowsercake
I also think you might be pushing the accent too far and are hitting fuel cut. Without a standalone the ECU will always be holding you back. If you have enough money and time for a turbo setup you should have enough money and time to complete your setup correctly with proper fuel management.
bowsercake is offline   Reply With Quote Quick reply to this message
Old 08-11-2008, 09:50 AM   #4 (permalink)
alexlab79
you are comic!
the probleme is solved...is only the gap in spark plug!
my fueling is perfect, i am electronic/informatique tech and i have made my personal piggy back, it's run perfectly now, the gaz pressure is more with boost and hyundai ecm is cheated. he see very lean a/f ratio when i am in boost, i am able to control what ecm see with rpm and boost level. Another cheat, the Ecm believe i am at wot all time he see 2 psi and more, it's for fuelling based on O2 sensor when boost and not based on tps sensor
The Ecm see 148Kpa without problem! 148Kpa= 7psi of boost + 14.5psi(normal earth pressure)
