Codes P0304 & Po441 - Hyundai Forums : Hyundai Forum
Old 07-01-2008, 06:07 PM   #1 (permalink)
2012 Veracruz Limited AWD 2012 Sonata Limited 1966 Ply. Barracuda Formula S 273-V8-4spd-4.10gears
273HYPO
Thumbs up
car - 2004 Accent auto.- 1.6l - 97K miles
After battling a few months to get my check engine light - fault code P0304 to go off I finally remedied the problem with 3 bottles/fill ups of STP Gas treatment. This was about 1500miles ago. I go to DMV Inspection station and sat for an hour then wait anther 20minutes for the test to end and was given the big fat rejection sticker, she failed because the check engine light came on with fault codes P0304 & P0441. Now what the heck happened here? Just bad luck and coincidence or did their test set it off? Anyway the P0441 code is new and researched it is the Evaporative Emission Control System Purge Valve. Okay where is it, the HMA manual is not specific? In relation to the intake manifold where is it? Easy fix? And will this solve my P0304 code?
Let the replies roll fellas!!!!
273HYPO
273HYPO is offline   Reply With Quote Quick reply to this message
Old 07-01-2008, 06:59 PM   #2 (permalink)
byronguidry3732's Avatar
Dear 273,
P0304 Cylinder 4 misfire detected
Causes:
● Vacuum leak in air intake system
● CKPS circuit malfunction
● Ignition circuit malfunction
● Faulty ignition coil or pulg wire
● Spark plug malfunction
● Low compression due to blown head gasket, leaking valve or piston ring
● Low/high fuel pressure due to faulty
● pressure regulator,restricted fuel lines,plugged fuel filter or faulty fuel pump
● Fuel injector circuit malfunction
● Faulty fuel injector
● Faulty PCM
P0441 Evap Emission System incorrect purge flow
Causes:
● Open in battery circuit.
● Open in control circuit.
● Short to ground in control circuit
● Faulty PCSV
● Faulty PCM
Nice picture:
[attachmentid=8584]
Go to the HMA manual, DTC, and you get lots of nice pictures of the faulty items.
Byron
File Type: jpg 2004_Hyundai_Accent_Purge_Valve_lc15044111.jpg (25.3 KB, 223 views)
Where's my bailout?
Old 07-01-2008, 07:57 PM   #3 (permalink)
273HYPO
Thx, I could only find the outlined diagrams on the HMA site. Great pic. BTW is the PCM the position crank monitor????
Old 07-01-2008, 09:29 PM   #4 (permalink)
LilBean's Avatar
LilBean
No, PCM is powertrain control module.
LilBean is offline   Reply With Quote Quick reply to this message
Old 07-05-2008, 04:13 PM   #5 (permalink)
273HYPO
Replaced purge control valve and cleared cdes with my OBD. Drove her 20 miles and the code did not appear however the P0304 code is trouble some. I did the basics , checked plugs, wires, coil (sprayed water for arcing), sprayed carb cleaner around the head gasket and no fluctuation in idle. Car went on 1000mile trip w/o a problem...avg 33mpg w/ a/c on in 90* temps. Car idels smooth and no signs of misfire & smoth accerlation. I cleared the code for now. But where should I go from here?
Old 07-30-2008, 05:08 AM   #6 (permalink)
273HYPO
Okay, I added 2 bottles of STP gas treatment on July 3 and the CEL has not returned, better yet it passed state inspection!!!!!!!!!!! Man did I sweat that out...lololol
Old 08-16-2008, 02:40 PM   #7 (permalink)
Chelle's Avatar
Chelle
Thumbs up
Hi everybody, new on the forum and i have a problem with that code PO441
I have an accent 2000 1.5 engine and the check engine light went on. I checked with the scanner and the code was PO441 (the one that you guys are talking about). I erase the code and it has not come again (3 days since that), but i am noticing a problem.
[b]The last two times that i went to the gas station and put some gas, when i turn the key to start the car it crank but it don't start after 3 or 4 times trying. When it starts it does with difficulty, but it starts.
A friend of mine told me that the purge valve (the one that [b]byronguidry3732 posted in a photo) maybe is faulty.
*What's the main purpose of that valve? I have a light idea but i'm not sure.
*Could that valve be faulty? Not sure since i don't have any codes?
*Or since i erase the code it will come up after a few cycles because the problem is there?
[b]PLEASE HELP ME, I DON'T WANNA WASTE MONEY BUYING PARTS THAT WON'T SOLVE MY PROBLEM!
Chelle is offline   Reply With Quote Quick reply to this message
Old 08-17-2008, 08:30 AM   #8 (permalink)
273HYPO
The purge control solenoid valve controls the fuel vapor emissions. Just a hunch but when your filing up and its hard to start there maybe a correlation in which the the quantity of gas now in your tank is not vaporizing properly even though it hasn't given you the code again. Or it could be your charcoal cansiter near the fuel tank which is pricey to repair. I would go ahead and replace the purge control valve since that was the initial code. I got mine for $37. from the dealer and less than two minutes to repair. Keep us posted.
273HYPO
Old 08-17-2008, 08:38 AM   #9 (permalink)
273HYPO
Okay now when the wife fills up and tops off the tank the CEL lights for code P0304. And when I add a bottle of STP it goes out in 100miles or so. Any thoughts felas. Charcoal canister? If so, wouldn't I get a different code and it wouldn't take a full fill upand hard to pump gas into the tank.
273HYPO
Old 08-17-2008, 10:06 AM   #10 (permalink)
Chelle's Avatar
Chelle
Thanks for your advice, i'll keep you guys posted!
