How To Change Headlight Bulb - Hyundai Forums : Hyundai Forum
Old 06-02-2007, 04:14 PM   #1 (permalink)
Amer303
hi can anyone tell me how to change the headlight bulb on a 2002 accent.?
the manual say to disconnect the power cord from the bulb but i dont want to push it to hard . and what screws do i have to take out? any tips would help me
thank you everyone.
and yes am new here lol.
Amer303 is offline   Reply With Quote
Old 06-04-2007, 03:54 PM   #2 (permalink)
jayg
In my 2001 Accent it is very straight forward ... Simply disconnect the power from the back (pull away from light) .. Remove the dust cap (simple rubber backing). Then should be able to remove the clip that holds the bulb in place (unclip then swing away). The manual should show how that works. Then put new bulb in and do the reverse .. make sure the clip is in tight, and verify the lights shine straight (according to specs in manual) .. I don't think you need any tools. Although my Drivers side is usually a bit harder to change since the battery is very close to the headlamp.
-Hope that helps
jayg is offline   Reply With Quote
Old 06-04-2007, 04:23 PM   #3 (permalink)
truss64130's Avatar
truss64130
I usually end up taking out the whole light assembly because of the close proximity of the battery. I think it was only two bolts to remove each light. You would then have to disconnect the turnsignal / parking lamp connector though. I find it easier to see the lamp clip that way.
truss64130 is offline   Reply With Quote
Old 07-08-2007, 09:44 PM   #4 (permalink)
Amer303
thx alot guys that help me alot
i changed the bulbs but i didnt know how to put back the springs that hold the bulbs so its very loose right now the only thing holding it the dust cover so any ides how to put it back together .
