2002 Accent Fuel Filter - Hyundai Forums : Hyundai Forum
Old 04-08-2005, 03:32 PM   #1 (permalink)
cxhernandez
Does anybody know where the fuel filter is on a 2002 Accent GL located at
cxhernandez is offline   Reply With Quote Quick reply to this message
Old 04-08-2005, 09:54 PM   #2 (permalink)
BH206's Avatar
BH206 is an unknown quantity at this point
Send a message via ICQ to BH206 Send a message via MSN to BH206
I will guess underneath the rear seats.
BH206 is offline   Reply With Quote Quick reply to this message
Old 04-08-2005, 10:33 PM   #3 (permalink)
VALKYRIE YB70's Avatar
VALKYRIE YB70 is an unknown quantity at this point
Full instructions are here :-
Click here
Cheers,
Nick.
Front-mounted Intercooler with silicone pipework
Re-cycling BOV
Ecotek unit
K&N cone filter with ram + 12v. fanned cold air
Adjustable fuel pressure regulator
2.5" dia. custom cat-back stainless steel exhaust
15"x7" TSW alloys
Spax lowering springs over Pedders struts
Rear track increased by 2.5"
Alloy front strut brace
Manual boost controller running 12 p.s.i.
Upgraded cockpit with replacement 6-speaker C.D. system
My S-Coupe Turbo Slideshow :-
http://aol.photobox.co.uk/slideshow/index....?c_album=546423
VALKYRIE YB70 is offline   Reply With Quote Quick reply to this message
Old 04-09-2005, 12:33 AM   #4 (permalink)
buzzy
I serviced the wifes accent this morning , do you think i could find that $#%@* fuel filter? Thanks guys i couldnt beleive it when i joined this forum and found the answer straight away. Why isn't it shown in the service manuel or have i just overlooked it?
It`s all here! :- http://www.hmaservice.com/webtech/default.asp
buzzy is offline   Reply With Quote Quick reply to this message
Old 04-23-2005, 05:31 PM   #5 (permalink)
dallnut
THE FUEL FILTER IS LOCATED UNDER THE REAR SEAT CUSION. PRY THE FUEL PUMP COVER UP. IT IS FASTENED WITH STICKY SEALENT. THE FILTER IS IN PLANE SITE TO THE RIGHT OF THE PUMP. NO TOOLS ARE MEEDED TO CHANGE THE FILTER. UNPLUG INE WIRE CLIP AND THE INLET AND OUTLET FUELLINES. HOPE THEIS IS HELPFUL TO YOU. DARRYL
dallnut is offline   Reply With Quote Quick reply to this message
Old 02-28-2007, 07:54 PM   #6 (permalink)
username
^ your the man.
how do you put the cover back on??? will it stick back on? or can you get the sealeant?????
username is offline   Reply With Quote Quick reply to this message
Old 03-01-2007, 09:44 AM   #7 (permalink)
truss64130's Avatar
truss64130
I just stuck mine back on. I'm sure it is not as sealed as it once was, but it still takes effort to pry it back off.
Also, have a towel ready because when you disconnect the gas lines, a small amount to gas will leak out.
truss64130 is offline   Reply With Quote Quick reply to this message
Old 03-02-2007, 08:33 AM   #8 (permalink)
username
yeah, I just gently pryed it up and off the metal. Then just pushed it back down it reseal pretty good. hopefully from people sitting in the back, it'll sinch down more.
Easy job though.
Old 01-29-2009, 05:28 PM   #9 (permalink)
Mulepick
How do you undo the clamps on the front of the cushion?
Mulepick is offline   Reply With Quote Quick reply to this message
Old 02-19-2009, 11:11 AM   #10 (permalink)
nalbanese
QUOTE (Mulepick @ Jan 29 2009, 05:28 PM)
Just push in on the black tabs at the bottom of cushion and lift.
nalbanese is offline   Reply With Quote Quick reply to this message
