Beta Swap / 2000 Accent Engine Swap - Hyundai Forums : Hyundai Forum
Register Home Forums Active Topics Photo Gallery Members List Calendar Search Today's Posts Mark Forums Read
Old 03-20-2005, 05:30 PM   #1 (permalink)
jmpetty
I was wondering about beta engine swaps into the accent. This means that the Tiburon engine is being put into an accent? Is it the 2.0L Tiburon enigne? How difficult would it be to do one of these swaps into a 2002 Hyundai Accent manual with 1.5L in US? Would it be worth the time/effort with the increase in performance or would it cost more for installation,etc. then it is worth? Thanks.
jmpetty is offline   Reply With Quote
Old 03-21-2005, 10:02 PM   #2 (permalink)
Omimiles's Avatar
Omimiles
Arrow
it is a good swap, the car will responde better, and good performance, a thing i know is that if you make the swap u can install the A/C , but the car will respond better, I guees i would make a swap also
Omimiles is offline   Reply With Quote
Old 04-03-2005, 04:22 AM   #3 (permalink)
coqui787's Avatar
coqui787
Anyone know of an engine swap I can do to my '00 Accent? Not too many performance upgrades available for mine. Considering swapping engine. Anyone else hear the rumor about a Tiburon engine in an Accent?
coqui787 is offline   Reply With Quote
Old 04-03-2005, 05:06 AM   #4 (permalink)
soullink
Send a message via MSN to soullink
Arrow
The Tiburon engine swap is a reality - but I only know of one place that does it and they are in Australia (www.PerformanceStylingCenter.com.au) and I don't think they will tell you how to do this - but it can be done. A guy in the UK is currently havin a 2.0 litre Coupe engine put inti his X3 Accent - but it is a lot of work and will cost a lot of money for a garage to do (and take a lot of time).
soullink is offline   Reply With Quote
Old 04-03-2005, 10:06 PM   #5 (permalink)
accentdental speed's Avatar
accentdental speed
Send a message via AIM to accentdental speed Send a message via Yahoo to accentdental speed
Engine swaps can be tricky in any car, but the accent is pretty good when it comes to room for different engines. I swapped the 2.0L from a 2000 Elantra in last year. It makes 140 hp so I should be pretty well off, considering it's only 4 cylinder. I had to make custom mounts because the bolts didn;t line up with my factory cradle very well ( go figure :P ) so the only real hard part was getting the wiring to work. I e-mailed the guys at Hyundai and the ysend the diagrams for my accent and the elantra, so all i needed to d owas cross-splice the wires. I do this for a living though, so I had no problem. I did still take me about 5 hours. Once the engine is installed the exhaust is another story. I upgraded to a larger pipe, so I custom fabbed the whole header/downpipe assembly. I used 321 sus steel so I know it'l be on for a long time. My plans are for a turbo system this spring, so I will probably try and sell the headers to some guy with an elantra. I think i'm gona use the T66 turbo, but i'm not final yet.
accentdental speed is offline   Reply With Quote
Old 04-03-2005, 10:23 PM   #6 (permalink)
Omimiles's Avatar
Omimiles
Arrow
Here in Puerto Rico are a los of Hyundai Accent with that swap, the most I'l ready saw is in the 95-99 Accents, but in the 2000-up i saw a few, look this one is a Accent with turbo tiburon engine running low's 10 at the 1/4 mile, NO nitro
And this other running 9.7 at the 1/4 mile with a Turbo NItrous TIburon Engine
here running vs the world fastest EVO 8
mano, ese swap se puede hacer segun eh visto, ah cambiar algo de la rabisa y creo q no se puede montar el aire acondicionado por el espacio, pero na si kieres entra a carrito.net, y alli te dan la mano,
Old 04-03-2005, 10:32 PM   #7 (permalink)
hyundai-power
umm... how about in English?
hyundai-power is offline   Reply With Quote
Old 04-03-2005, 10:36 PM   #8 (permalink)
Omimiles's Avatar
Omimiles
Arrow
sorry, I say that, that engine swap could be done, I guees the A?C cannot be fit, there no space for the A/C compressor, he need to change some of the engine support and the ECU, and i say to him, that he can go to a webpage of Puerto RIco, where he can find somehelp
Old 04-03-2005, 10:38 PM   #9 (permalink)
hyundai-power
ahh, ic
Old 04-03-2005, 10:41 PM   #10 (permalink)
Jade01Accent
Send a message via AIM to Jade01Accent
OKay I'm curious to know who won between the Evo and the Accent!! I'm almost sure the Evo won.. but then again u never know... Oh and english please....
Jade01Accent is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
