LinkBack | Thread Tools |
#1 (permalink) |
Hyundai Accent 2005 Model - Right hand Drive
HI
is it safe to do a fault scan using a ELM327 obd scanner even if the check light is not on. i did a scan for fault codes even thou the checklight is off and after removing the device, my engine sound had changed and it is now noisy when AC is on. This was never an issue, it just began after i plugged the ELM327 bluetooth adapter. I used the android TORQUE application for scanning the fault codes. Please help... Also i am unsure on how to use the device? do we turn the engine on and do a scan or just have the engine in ignition mode and then do a scan? Also is it safe to do a fault scan even if engine check light is off? do we have to still erase codes on ecu even when there was no faults found? |
| Sponsored Links | |||
Advertisement | |||
#5 (permalink) |
yes changed abit of stuff.
so is it okay to also disconnect the adapter while the car is running? why is it that in the torque application, in the IM Readyness since dtc clear screen, all items are shown as not applicable. |
#7 (permalink) |
I have a ELM327 obd scanner as well and does a great job on my Kia as well my Hyundai. Blue tooth to the smartphone (Torque). Someguy is right. All it does is read data and nothing else......But is a great little tool for the price.
#8 (permalink) | |
12 Veloster
08 Accent GLS(R.I.P.)
08 Bullitt Mustang
04 Yamaha FZ6
82 Dodge D150
83 Iveco Z110
Go ahead and "buy up" - it's not expensive.
Parfois, on fait pas semblant! |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
