2002 Accent , After the timing belt breaks when running - Hyundai Forums : Hyundai Forum
Old 12-20-2012, 05:10 PM   #1 (permalink)
Hyundai Accent 2002
questar is an unknown quantity at this point
Default 2002 Accent , After the timing belt breaks when running
The timing belt while going 75 mph. The belt has been replaced, the tensioner, plugs, and belts. After turning the key, it will not start. I wondered if it was damaged while turning with a broken belt. If so, what is needed to get it running again ?
questar is offline   Reply With Quote Quick reply to this message
Old 12-20-2012, 05:34 PM   #2 (permalink)
Drives 01' Accent GS 1.6 DOHC
01Accent16
A new motor is needed lol. Everything was fist bumping inside.
01Accent16 is offline   Reply With Quote Quick reply to this message
Old 12-20-2012, 05:45 PM   #3 (permalink)
Drives Accent '02 Drives Accent '04
Barnyspup is on a distinguished road
Well, at least a new head is likely.
Pics of possible damage here:
Interference engine - Wikipedia, the free encyclopedia
Do a compression test to confirm.
Jim
Barnyspup is offline   Reply With Quote Quick reply to this message
Old 12-20-2012, 06:34 PM   #4 (permalink)
Hyundai Accent 2002
Default Valves and guides only?
Wouldnt the valves and guides be the only thing affected?
Old 12-20-2012, 07:09 PM   #5 (permalink)
Hard to tell till disassembly.
Could damage camshaft lobes/lifters, even piston tops.
Yet some folks get lucky and it stops dead where nothing is hitting.
Whatever, you're looking at expensive repairs. Time to evaluate whether car is worth it.
If you're a gambler, maybe a scrap yard engine.
Jim
Old 12-21-2012, 07:10 AM   #6 (permalink)
01Accent16
My 98 Olds Cutlass with the 3.1 V6 got screwed over. Replaced the headgsket, mislabeled the intake and exhaust push tubes for one cylinder. In the end, I punched a push tube thru a rocker, valve hit the piston. No compression. The only way to have compression was to shim the rocker and pour some oil in the cylinder. Even that only produced about 20psi.
Old 01-08-2013, 08:30 PM   #7 (permalink)
Drives 2006 Hyundai Accent (LC model)
BirdMan89 is an unknown quantity at this point
Its also possible that the valves snapped off and got rattled around inside the cylinder, causing cylinder and piston damage. It might be repairable but you also might be better off replacing the engine or car.
BirdMan89 is offline   Reply With Quote Quick reply to this message
Old 01-09-2013, 11:25 AM   #8 (permalink)
newhyundaier
A good used 1.6L hyundai engine is very cheap. I found one a couple of years ago for $250, and it's still running great in my accent. That $250 engine was from a totaled 2005 accent, and only had about 80k miles(checked at carfax with the VIN#).
newhyundaier is offline   Reply With Quote Quick reply to this message
Old 01-10-2013, 07:52 AM   #9 (permalink)
Twok
I have a 2001 Accent with 138,000 on it. I drive 39 miles (1 way) to work. Either when I got work and stopped the car or started it when I was leaving the belt broke. Put a new belt on. Friend did a compression check and could not believe that it did no damage. That was about 7 months ago and still runs great. ;-) ......75 mph and a popped belt. You should of heard some form of clanging and banging. Sorry about your loss.
Twok is offline   Reply With Quote Quick reply to this message
